Results 1 to 10 of 14
Thread: 2009 3l Nissan Patrol Y61 Ti, blowing black smoke!
    Aug 2015
    BUNBURY WA
    Question 2009 3l Nissan Patrol Y61 Ti, blowing black smoke!
    Not sure if this is the right place or not...... New to this forum.
    My Nissan Patrol randomly drained it's fuel lines one night ( no holes or leaks) then is started blowing heaps of black smoke. After discussions with a mechanic, We changed the sensor on the air filter bit, no change. Took it to a fuel injection place in town and they tested it with a Valve Block afte smoking out there workshop........., apparently it worked and reduced the smoke significantly, but due to the legalities they could not leave it in. We have bought the car home and made a valve block as per the gasket which is on the intake, test drove it and it still blows excessive smoke...... Any ideas what else to try? Don't think my neighbourhood enjoys being smoked out.....
    Nasty Dog - Moderator Woof's Avatar
    Perth WA
    63 Post(s)
    Hey mate, slip over here http://www.nissanpatrol.com.au/forum...-Introductions and post up an introduction, it is something we like all new members to do before asking for assistance so we can welcome you, that way everyone gets a nice warm fuzzy feeling
    Aug 2015
    BUNBURY WA
    Just done my introduction
  4. The Following User Says Thank You to Sam144 For This Useful Post:
    threedogs (17th August 2015)
    Patrol God Sir Roofy's Avatar
    TRAFALGAR VIC
    35 Post(s)
    Clean the MAF sensor check that inter cooler hoses are seated and tight maybe check the fuel filter not sucking air
    Aug 2015
    BUNBURY WA
    We Cleaned the MAF sensor...... no change, so we replaced with a new one....... no change!
    New fuel filter was fitted Friday..... no change either
    I assume the mechanic would have checked the hoses but will double check tonight... since putting the valve block in there is a definite increase in power but its just the excessive amount of smoke still.....
    Do you know what boost you are reaching? is your IC oily if so its leaking, they all do.
    Relpace it with a tested, tigged unit for around $400. You really need to get gauges and a catch can fitted.
    Then you can see whats going on. Check all hoses on the IC for splits and if fitted correctly.
    Without gauges you are just flying blind, black smoke = too much fuel or not enough air.
    See if you can swap your MAF sensor with one you know is working, even from new they are hit and miss.
    PM Mudski for your Nads requirements if you go down that road, most do. Also google Chaz Yellowfoot for all things
    ZD30 related.
    Having a common rail that erg plate you made needs a 10mm hole in it or you will get check engine light,
    A scangauge is the best bit of kit you can buy for your model, i have a ECU-Talk for my Di.
  8. #7
    Legendary 4bye4's Avatar
    Aug 2014
    Kingsley WA
    15 Post(s)
    What motor and what transmision mate?
  9. #8
    gday mate, check out our thread on your exact problem, it will probably go a long way to helping you diagnose what your problem is!!
    Why Diesels Smoke
  10. #9
    Aug 2015
    BUNBURY WA
    Have just bypassed the wastegate vaccum controll so waste gate closed full time .... no more smoke but really touchy on throttle what controlls the opening of the wastegate???
    thanks in advance
  11. #10
    did you disconnect the battery for an hour after doing the Maf mate?
