Results 1 to 10 of 12
Thread: GU Patrol Engine check light
    Beginner rjacko's Avatar
    Aug 2015
    Darwin NT
    I have a 2003 GU patrol 3.0 with 325000km on the clock . The only engine modification is a Roo Systems exhaust and chip which I fitted 3 tears ago.
    Recently my engine check light came on so Off the mechanic I went,
    he put the analizer on and got a low boost indication and he also found:
    1. two snapped studs.
    2. leaking intercooler
    3. damaged gaskets.
    He fixed the above and cleaned the inlet manifold and EGR, replaced the intercooler with a second hand one (which had less leaks).
    After this the engine ran better but after running for about 5 minutes under load the engine check light came on, this occured after 3000rpm in 2nd or 3rd gear. He traced the engine check light to a faulty senser on the intercooler, so we put another second hand one in and the light went out.
    I have driven the car for a week no light and this morning it came back on.
    I have also put in a new fuel filter and a catch can.
    When the light came on yoiu cabn notice the drop in power around 2500 to 3000 rpm.
    Any suggestions?
    176 Post(s)
    Is the egr blocked ??? Is there anyway for you to check for codes by means of scan gauge or something.
    Aug 2015
    Darwin NT
    The EGR was checked by the mechanic and he said it was OK, I have no gauges but the mechanic has the engine check equipment and used that. I have had no issues for the last 13 years so never looked at these forums and have not installed gauges to monitor the boost or temp. Not sure how to install them there is probably a thread somewhere about that.
    Patrol Freak kevin07's Avatar
    georges hall
    first new intercooler tig welded 2nd hand is no good. and block your egr and pm mudski for a boost controller and needle valve.but if you could get the actual code its throwing would be good.
    13 y62 the beast that burbles
  5. The Following User Says Thank You to kevin07 For This Useful Post:
    Hodge (16th August 2015)
    Aug 2015
    Darwin NT
    Thanks I will get the codes tomorrow arvo and post them. I am ordering a new intercooler tomorrow.
    176 Post(s)
    Get the codes and a tig welded IC, as no matter how many factory ones you put on they all leak. I asked about the EGR, as some 3 liters like to throw out an engine light every now and then, and then other times not.
    Less leaks isnt a fix sorry, source a Tested fully tigged one. around $400.
    you'll also need imo to fit a boost and EGT gauge. that way after you fit you Dawes manual boost
    controller and needle valve ,you'll know whats going on under the bonnet,
    Do all these things then take the Patrol for a dyno tune, you will be sursprised
    WhicH Chip do you have? and what is it set one
    PM Mudski about your NADS requirement
  9. #8
    Aug 2015
    Darwin NT
    I have PMed Mudski
    I INSTALLED A N-RS-057 ROO SYSTEMS POWER MODULE,not sure what it is set to just installed it from the box in Oct 2012. I have had no issues until now.
  10. #9
    Aug 2015
    Darwin NT
    Does anyone know where I can get a dyno tune in Darwin
  11. #10
    476 Post(s)
    Quote Originally Posted by rjacko View Post
    Don't bother with a Dyno on these motors IMO. Unless you want to know the power output. You can road tune these motors pretty well once the NADs are in and save yourself the coin of a dyno.
  12. The Following User Says Thank You to mudski For This Useful Post:
    rjacko (18th August 2015)
