Page 14 of 28 FirstFirst ... 1213141516 ... LastLast
Results 131 to 140 of 280
Thread: Winnie's Warn hi mount rebuild
  1. #131
    22 Post(s)
    For someone to say they will sell it to you cheap is definitely worth the question of how much!
    Didnt you get yours for free?
    96 GQ coil/Cab
    08 G6eT
  2. #132
    Lol. It would be still too dear for him....
  3. #133
    Yes I did, wasn't yours for free too?
  4. #134
    22 Post(s)
    It sure was.
    96 GQ coil/Cab
    08 G6eT
  5. The Following User Says Thank You to Ben-e-boy For This Useful Post:
    AB (16th August 2015)
  6. #135
    It sure was.
    You two should get a room.
  7. #136
    @ Winnie if you are spray can painting it, can I suggest that you heat up each
    part to open up the metal a bit, paint sticks better too, a floor radiator is enough
    Used this method on motor cycle tank.
  8. #137
    It would have to be free. They're too tight to pay for things!
  9. The Following User Says Thank You to Winnie For This Useful Post:
    mudski (16th August 2015)
  10. #138
    Why pay when they're free?
  11. #139
    Well I've again ditched the sand blasting idea because I don't want to have to strip all the bearings and the sand will ruin them. I will use a wire wheel to clean it.
    In saying that I might still sandblast the lower housing and fill the needle bearing with wax to keep the sand out, there are too many tight spots that are full of dirt and crap that would be a nightmare even with a die grinder.
    So the wire wheel will scratch it up nicely for paint. Not sure if I will need to use etch primer or not? Darren?
  12. #140
    Come up pretty good with the wire wheel! Just need to use the sand blaster to get the hard to get bits.
  13. The Following 3 Users Say Thank You to Winnie For This Useful Post:
    AB (20th August 2015), MudRunnerTD (20th August 2015), Rossco (20th August 2015)
