Page 17 of 46 FirstFirst ... 1516171819 ... LastLast
Results 161 to 170 of 456
Thread: Rockets Wagon
  1. #161
    Patrol Guru Rocket55's Avatar
    Sydney
    Fitting was pretty easy to fit, just bolts in. All the instructions are included and are easy to follow. I did have to tidy up a weld on the top of my drivers side chassis rail to allow it to sit flat. This was also in the instructions as a possible action. Hardest part is lifting it on, you will need to find a friend to give you a hand for a couple of minutes, other than that it's a one person job.
    Cheers Rod
    My Build 2005 TD42TI
  2. The Following User Says Thank You to Rocket55 For This Useful Post:
    Hodge (15th August 2015)
  3. #162
    177 Post(s)
    Thanks again Rod. With my 3L i un-installed a kaymar rear bar, which more or less I imagine, will be the same bolt on system as this one.
    Cheers !
    Sydney
    I imagine so. There's 8 bolts. 2 on each side at the back of each guard, and the 4 that hold on that hoop in the centre of the rear bar.
    Cheers Rod
  5. The Following User Says Thank You to Rocket55 For This Useful Post:
  6. #164
    Sydney
    Busy arvo today, out with the old and in with the new
    While I was there I flipped the tail shaft around in preparation for longer shocks
    In doing this a found one of the uni's had a slight unevenness in its movement which probably explains the slight vibration I get at speed. When I do the engine work I'll sent the shaft away for a couple of new uni's. Also hoping that in the mean time by flipping the shaft and correcting the pinion angle some of the vibration goes away.
    Tomorrow I'll tackle the front end.
    Cheers Rod
  7. The Following 3 Users Say Thank You to Rocket55 For This Useful Post:
    Hodge (16th August 2015), Rossco (16th August 2015), Skitzyrex (16th August 2015)
  8. #165
    177 Post(s)
    Very nice. Shit mate you're going all out on this rig aren't ya?
  9. The Following User Says Thank You to Hodge For This Useful Post:
    Rocket55 (17th August 2015)
  10. #166
    Mate I wish I had both the time and $$$ u do!! Love the work though have to say I'm very jealous
    Sent from my E6782 using Tapatalk
  11. The Following User Says Thank You to rusty_nail For This Useful Post:
    Rocket55 (24th September 2015)
  12. #167
    Sydney
    Turn out this is a maintenance activity ... It's resolved a lot of bangs and rattles, should have done it long ago.
    Cheers Rod
  13. #168
    Sydney
    Can't take it with you mate. As for the time, well there's 24 hours in a day. Day time with the family (or work), night time with the Patrol. Just makes it a bit harder as using a rattle gun at 11pm tends to upset people, don't know why...
    Cheers Rod
  14. The Following User Says Thank You to Rocket55 For This Useful Post:
    rusty_nail (17th August 2015)
  15. #169
    Sydney
    Well replaced all the front arms today. Panhard, tie rod and drag link. The radius arms are later on. Was all pretty straight forward. Used the trolley jack to put a bit of pressure on the bottom of the ball joints then given a whack with a hammer and out they pop no problems. Measured the arms as best I could, but it will need a wheel alignment, although it drives pretty good so I must have gotten it pretty close.
    Can't believe how much better it drives now, bumps are bumps and not crashes which reverberate back up through the body.
    Very pleased with how it came out. I ran out of Locktite so will need to get some more during the week to finish it off properly.
    Cheers Rod
  16. The Following 3 Users Say Thank You to Rocket55 For This Useful Post:
    Hodge (1st September 2015), mudski (18th August 2015), rusty_nail (18th August 2015)
  17. #170
    Sydney
    First of the bits have arrived
    Cheers Rod
