Page 150 of 570 FirstFirst ... 148149150151152 ... LastLast
Results 1,491 to 1,500 of 5698
  1. #1491
    477 Post(s)
    Finished off my wiring for the two Redarc gauges. Cuppa, if your reading this, all sorted mate. Mental note to self. RTFM! Twice.
    Also cleaned up a little ready to ship the troll off to the workshop tomorrow.
    Cuppa (12th August 2015)
  3. #1492
    Ballarat, Vic
    178 Post(s)
    Well done. Yep .... When all else fails RTFM. LOL
  4. #1493
    Expert SiberianPatrol's Avatar
    Jul 2015
    Siberia
    Today I bought new kingpin spacers for the front end as well as a new drive-shaft for the passenger side (driver's side for you Aussies). One of the previous owners apparently removed the kingpin spacers for some weird reason and he also never checked his front driveshaft bearings. it was completely dry - no grease in it whatsoever so it was partially seized up and destroyed from lack of lubrication.
    One of many things I'm now finding out about the vehicle. No big deal. At least I know what I have now and that things are done right.
  5. The Following User Says Thank You to SiberianPatrol For This Useful Post:
    Stropp (13th August 2015)
  6. #1494
    Patrol Guru Rocket55's Avatar
    Sydney
    3 Post(s)
    Redarc Tow Pro
    Cheers Rod
    _______________________________________________
    Bitumen ...... Another watse of public funds
    My Build 2005 TD42TI
  7. The Following User Says Thank You to Rocket55 For This Useful Post:
    mudski (12th August 2015)
  8. #1495
    Patrol God Stropp's Avatar
    38 Post(s)
    Quote Originally Posted by SiberianPatrol View Post
    i think you will find that there are some people who remove those spacers to stop the front wheel wobble which is common but dont check the preload on the bearings and what it does is put too much pressure on the bearing and it shits itself like your have. good luck with it mate sounds like you will get it sorted.
  9. #1496
    Jul 2015
    Siberia
    I remember reading about doing that, but that just serves as a quick fix and doesn't address the root problem. From my understanding, the real solution was to replace the kingpin bearings? I'll have to try to dig up that thread or find where I read that. Is there something else I should do to prevent the death wobble?
  10. #1497
    Sydney
    3 Post(s)
    Td05 18g
    12mm pump
    CC cooler and scoop
    Injectors
    4" Snorkle
    4" airbox and piping
    Clutch
    Cheers Rod
  11. The Following 4 Users Say Thank You to Rocket55 For This Useful Post:
    Bacho86 (13th August 2015), Hodge (13th August 2015), mudski (13th August 2015), Winnie (13th August 2015)
  12. #1498
    177 Post(s)
    Quote Originally Posted by Rocket55 View Post
    Td05 18g
    12mm pump
    CC cooler and scoop
    Injectors
    4" Snorkle
    Clutch
    Holy ....
    Going all out mate... That'll be a beast.
  13. The Following User Says Thank You to Hodge For This Useful Post:
    Rocket55 (13th August 2015)
  14. #1499
    Sydney
    3 Post(s)
    Na, just something that's nice to drive and tows well
    Cheers Rod
  15. #1500
    477 Post(s)
    Td05 18g
    12mm pump
    CC cooler and scoop
    Injectors
    4" Snorkle
    Clutch
    Nice Rod. Definitely gonna be different. not sure on the snorkel myself yet. I like the 4inch pipe setup but after reading a few peoples thoughts, if you have the pax window open, its quite noisy....
  16. The Following User Says Thank You to mudski For This Useful Post:
