Page 538 of 1057 FirstFirst ... 536537538539540 ... LastLast
Results 5,371 to 5,380 of 10566
  1. #5371
    Today I plan on changing my bonnet struts and then maybe fitting my awning.
    Maybe even drill some holes in the bullbar for some bulls eye 9watt DRLs.
    Then again it could all go pear shaped. lol
    Edit; Bonnet struts done should have done it years ago lol
  2. The Following User Says Thank You to threedogs For This Useful Post:
    Hodge (8th August 2015)
  3. #5372
    Expert SiberianPatrol's Avatar
    Jul 2015
    Siberia
    What did you do to your Patrol today!
    How many leds on each globe I found 120 smd led per globe on ebay very bright
    so 240 smd led each side, 480 total
    Nothing like that, unfortunately. The LEDs are only on the red brake lights. Reverse and indicator lights are standard bulbs. Not an expensive swap, so I'm not concerned about it.
    The only problem that I ran into was that since this is a European model, there are no wires for the reverse or indicator lights on the right-hand side (drivers side for you Aussies). When I get more time, I'll try to figure out how to rewire those in so I have a full working set.
  4. #5373
    84 Post(s)
    I took the covers off
    both upper front spring
    mounts and washed out the damp
    dirt on Wednesday. After rinsing
    them out a couple of times,
    using a coarse brush,
    I treated them with Feronite.
    I coated them with an
    anti-chip paint, yesterday
    and put the covers on today.
    I urge you all to check under
    the plates after any off road
    driving and every couple of
    months as rust had already
    set in.
  5. The Following User Says Thank You to mudnut For This Useful Post:
    threedogs (8th August 2015)
  6. #5374
    Nothing..... bloody raining all morning so far
  7. #5375
    Quote Originally Posted by SiberianPatrol View Post
    STD our rear lights dont work, we only have one T20 reverse globe.
    I've put 68 smd White globes behind the red and amber len's.
    You can buy a kit to wire up the "dummy" lights but you have to drill new holes to accept new globe sockets.
    I think they use Ford twist / lock globe sockets
    Some PPL wire them up as extra indicators, but I thought reverse would suit my needs better.
    Our lights are in those plastic bumperettes, avoid putting red globes behind red len's.
    I only paid $4 not much more for my globes and still going strong 5 or so years later.
    Every globe is LED except the front OE amber one, I couldn't find one bright enough for daylight use.
    Plus indicators have 50ohm resistors on all 4 globes to stop the fast flash
  8. #5376
    Thomastown, Melbourne
    6 Post(s)
    Radius arm bushes... fun.
    Early start dropping Erica off for high school testing then past Mudski's to remove old bushes and fit new ones then home to install...
    A pleasure to drive now with no knocking noises.
    Another job off the list
  9. The Following 2 Users Say Thank You to Bloodyaussie For This Useful Post:
    Rossco (10th August 2015), threedogs (8th August 2015)
  10. #5377
    Patrol Guru
    Jul 2014
    6 Post(s)
    Went on a trip to wombat, lots of bopper, some winching.. Broke a sidestep, whoops!
  11. The Following User Says Thank You to Throbbinhood For This Useful Post:
  12. #5378
    177 Post(s)
    Quote Originally Posted by Throbbinhood View Post
    You know the rules mate. Pics or it didn't happen !
    Patrol Guru
    Jul 2014
    6 Post(s)
    Not of my sidestep, but me recovering a Toyota that had been stuck since Monday.. Poor bugger was pouring sweat with the shovel and a hand winch when we got there. He looked pretty glad to see us haha
  14. #5380
    A flat track and a little puddle. Yeah thats too much for a Yota! Lol
