Page 5 of 101 FirstFirst ... 34567 ... LastLast
Results 41 to 50 of 1003
Thread: Hodge's new 4.2
  1. #41
    Patrol God Stropp's Avatar
    36 Post(s)
    Well folks, I finally have an additional 1.2L sitting in my drive way. Very clean outside and inside 2005 4.2 turbo intercooled ST, in white, very low Ks !
    Drove it from Adelaide yesterday and pulls like a freight train! Took me a but of getting use to going from 3L to 4.2 in terms of power and clutch but I had 750km to do just that ... Couple of issues to address, but no dramas. Now to get RWC, book it in with Vicroads getting transferred and regoed and off we go.
    As soon as that is done first thing shes going in for a Snorkel and 3" pipe to let her breathe a bit better.
    Nice pickup mate, low k clean car to start with,
    Mine looked like that once ��
  2. The Following User Says Thank You to Stropp For This Useful Post:
    Hodge (29th July 2015)
  3. #42
    176 Post(s)
    Mine looked like that once 😜
    Thanks mate. My 3L was a spitting image of this when I bought that too and didn't look like that for long though. lol Just a few minor issues to sort out, and shes sweet. Underneath is getting cleaned up and sprayed soon for that new look. And I think my left hand side (passenger) engine mount is on it's way out. So I'm told, it is common ?????
    Also snorkle and exhaust are ordered and waiting for parts. Gonna let her breathe properly first.
    North brissy
    With 90k I would think the engine mount should be ok. But yes the passenger side mount is common to wear and fail quicker just by the nature of the engine.
  5. The Following User Says Thank You to nissannewby For This Useful Post:
  6. #44
    176 Post(s)
    Cheers newby. I do get a little bit of vibration. But i'm so new to driving the 4.2 so, I don't know how much vibration is normal. Also looking at it and sticking a screw driver between the mount sandwich it is a tiny bit worn so, might get them changed next service which is soon.
    Patrol Guru Rocket55's Avatar
    Sydney
    3 Post(s)
    Around the 1,200 rpm mark I get a huge rattle or resonance coming from behind the dash towards the left hand side along with the door on the centre hidey hole between the air vents rattles it's arse off. Funnily it seems to do it more we coming down in the revs or holding a constant verses going up. Going around a round about in 2nd is a classic example of this. I'd do find if I just ease the clutch a tiny bit the vibration or rattle stops.
    Think I'm going to pull the dash out and sikaflex everything together.
    Cheers Rod
    _______________________________________________
    Bitumen ...... Another watse of public funds
    My Build 2005 TD42TI
  8. The Following User Says Thank You to Rocket55 For This Useful Post:
  9. #46
    176 Post(s)
    Cheers Rocket. I have rattle "somewhere" under the hood near the passenger footwell... I think. Only begins appearing when engine is warm and when taking off in 1st gear and just as I start applying the juice pedal. Same thing in 2nd gear when gearing up... I think it could be the exhaust or somewhere within the dump pipe area. So the exhaust that'll be fitted soon, will eliminate that as a possible cause I guess.
    Pulling the dash out is serious business I believe. Mine has the bubbles, and is way over Nissans 6 year recall date. It doesn't bother me as I can see them under the dash mat. Maybe a job for the future...
    Sydney
    3 Post(s)
    pulling the centre console part of the dash off is easy, then radio out, gets you at the centre. Glove box out gets you into the left had side. Then start glueing /cable tying shit together. Probably won't take much as you don't need to secure everything you just need to change the frequency at which it vibrates. I find with the centre pocket door, when it vibrate I only need to apply the smallest touch with my finger and it stops. Might stick a blob of bluetac on it and see if that works. If so a dob of silica nor a strip of double sided tape etc, anything just to change the frequency. Bit of trial and error.
    Cheers Rod
  11. The Following User Says Thank You to Rocket55 For This Useful Post:
    Hodge (30th July 2015)
  12. #48
    476 Post(s)
    Next time iseeyou Eric i need to give you an egr plate. Need to block that shizz.
  14. #49
    Sydney
    3 Post(s)
    I also removed the butterfly from the housing in the red circle, don't know what you call it.
    Between this and the EGR block, made it rev much freer and boost earlier.
    Cheers Rod
  15. The Following User Says Thank You to Rocket55 For This Useful Post:
  16. #50
    176 Post(s)
    Thanks gents. Will do that this weekend then.
