Results 11 to 20 of 21
Thread: i need a new cluch
    476 Post(s)
    Quote Originally Posted by Oldmate1 View Post
    everyone up here that i have tried is quoting between $2000 and $2500 i wish i could get it for $1600
    I think I paid around $1800 for one with the lot last time...
  2. #12
    Legendary dom14's Avatar
    38 Post(s)
    Dual mass flywheels basically have like a rubber dampener in between two steel plates. This is done purely to help remove any vibrations. But they often fail. Replacing ot with a solid flywheel you no longer have to have concerns about a fly wheel failure. The downside is you will have a little more vibration. Nothing to worry about in my opinion.
    They use high tensile springs to absorb the vibration, which has a certain lifespan like a clutch, apparently.
    It's based on the same principle as the harmonic balancer I reckon, except rather than using a clutch system, liquid or rubber, it uses springs due to the high torque it has to handle.
    I can understand replacing a cactus DMF. But, why replace a perfectly working one?
    Do they have such a bad reputation that they can break anytime for no reason?!!
    I'm guessing when the clutch dies we can have a look at the DMF as well and assess whether it's on it's way and replace if that's the case replace it with a SMF 'cos DMFs are pretty expensive to replace anyway.
    But, replacing a one in a perfectly serviceable condition is something I don't understand yet.
    Few more mods on the way
    https://www.panthera.org/
    Cheetah Outreach
  3. #13
    Patrol Guru Covo71's Avatar
    Dec 2012
    Coffs Harbour
    I bought the clutch and had it sent up for about $1100 and install was $500 or so.
  4. #14
    Apprentices Rule!!! Punderhead's Avatar
    Nov 2011
    Toowoomba, QLD
    They use high tensile springs to absorb the vibration, which has a certain lifespan like a clutch, apparently. It's based on the same principle as the harmonic balancer I reckon, except rather than using a clutch system, liquid or rubber, it uses springs due to the high torque it has to handle. I can understand replacing a cactus DMF. But, why replace a perfectly working one? Do they have such a bad reputation that they can break anytime for no reason?!! I'm guessing when the clutch dies we can have a look at the DMF as well and assess whether it's on it's way and replace if that's the case replace it with a SMF 'cos DMFs are pretty expensive to replace anyway. But, replacing a one in a perfectly serviceable condition is something I don't understand yet.
    It's the fact that mechanics can't guarantee them, and I sort of understand that. If I were to pay a mechanic God $$$ to do a clutch, only to have it fail in a month, I would demand refund/replacement. As such you are highly unlikely to find a mechanic who will reuse a dmf.
    Also, most kits to suit dmf come
    With the new dmf, and the clutch cannot be bought separately to
    The dmf. So if you have to buy it, why not Fit it while you're there!
    GO HARD OR GO HOME!!!
    My rig HERE http://www.nissanpatrol.com.au/forum...Moneypit-89-GQ
    WARNING: Towballs used in a recovery can and DO KILL people!!!
  5. The Following User Says Thank You to Punderhead For This Useful Post:
    dom14 (29th July 2015)
  6. #15
    Ballarat, Vic
    176 Post(s)
    What are the usual symptoms of a failing clutch - ?slipping under load or dragging? Sudden or gradual demise?
  7. #16
    North brissy
    Can be all of the above. Usually they will start to slip but can also just fail.
    A dmf can start to knock and give weird pedal feel when they fail.
  8. #17
    Patrol Guru Rock Trol's Avatar
    Mar 2013
    NE Melbourne
    The DMF can fail well before the clutch is worn out. And it can do it without warning. One minute its working well, no slippage etc. Next minute no drive t all. Happened to a mate of mine on a trip in the high country. We had just started up the stairway to lake Cobbler. Too narrow to turn around without any drive from the Patrol. I had to tow him over the top.
  9. The Following User Says Thank You to Rock Trol For This Useful Post:
  10. #18
    38 Post(s)
    Somehow I tend to think, when it comes to Patrols, there appear to be more sudden demise than gradual demise like slipping under load.
    Correct me if I'm wrong about that perceived statistic.
    If the clutch dies suddenly, I can only think of two scenarios.
    One is throw out fork bending or breaking
    The other is the pressure plate springs bending or breaking.
    I reckon both of the above do have some tell tale signs of failure, but would be hard to feel
    on the foot as all the 4WD clutches are hydraulic. So, it's a sudden failure as far as we know.
    What other things cause the clutch to have a sudden failure?
    I consider the hydraulic system failure as not a catastrophic failure, 'cos you can repair it on the road.
    Cheetah Outreach
  11. #19
    Dec 2012
    Coffs Harbour
    Not sure if the 4.2 is the same as 3lt but if the clutch gets to worn you can push the hydraulic piston through too far and pop it out which is what happened to me going home on a busy afternoon through Blue Mountains. Not fun.
  12. The Following User Says Thank You to Covo71 For This Useful Post:
    dom14 (30th July 2015)
  13. #20
    Hardcore
    central coast nsw
    Look it up on fleabay this may be your model excedy nsk 7699smf for you to confirm its correct.
    $1300 including delivery.
    I assume your quoting 2to 2500 is a fitted price.
    IF IT'S NOT A NISSAN.
    THEN IT'S A COMPROMISE
