Page 139 of 570 FirstFirst ... 137138139140141 ... LastLast
Results 1,381 to 1,390 of 5693
  1. #1381
    Advanced morton2478's Avatar
    Mar 2015
    Just orderd new intercooler
  2. #1382
    477 Post(s)
    Bull plop 3 dogs! They have got soft shackles on that website with a break load of 14 tonne!!
    Bahahahahaha!!!! I used to say that when I was in primary school.
    Quote Originally Posted by morton2478 View Post
    I'm hoping to take delivery of my Cross Country big banger early next week. Then I'll mount the fecker and then take some brave pills and cut the bonnet to fit the new scoop.
  3. #1383
    477 Post(s)
    Quote Originally Posted by Rocket55 View Post
    HD lower arms
    Adjustable uppers
    Front and rear panhards
    Tie rod
    Drag link
    Brake bias bracket
    2" spacers for the poly air bags
    Windscreen washer check valve
    ON the upper arms mate did you get one bent one? Just incase down the track you decide to get a long range aux tank you will need one... Pkus you'll need to do something about the radius arms too for the 3inch lift... Either drop boxes or those offset bushes.
  4. #1384
    Patrol Guru Rocket55's Avatar
    Sydney
    3 Post(s)
    No I just got the straight ones, at the moment a long range tank is not part of the plans (he says that now..). I'm hoping the economy I pick up from the engine work and a proper tune will help me out. Currently the front is sitting at 2" and the rear a bit higher, but I will be going 3" after I get the engine sorted. I need some bushes now due to clunking and banging so may as well get the arms and spread the cost out a bit so the missus doesn't get as upset. Eventually I'll probably be going hybrid arms and drop boxes on the front.
    Cheers Rod
    _______________________________________________
    Bitumen ...... Another watse of public funds
    My Build 2005 TD42TI
  5. #1385
    Sydney
    3 Post(s)
    Brave pills required and lock the beer fridge up until after the job in this case.
    Cheers Rod
  6. #1386
    On the link I saw they were only low breaking point. have a read so double bull plop lol
    I'm sure they have bigger ones available just not on the link I saw.
    It should be mandatory to use them instead of steel shackles
  7. #1387
    Many different sizes as they are huge in the sailing world.
    Our problem is why would you pay $30-$50 each when a rated metal shackle is below $20..
    The only advantage the soft shackle has is the safety.
    Sent from my SM-G800Y using Tapatalk
    On a different note.
    Just bought this.
    $214.. very good price.
    Will modify battery tray tonight.
    And less weight
  10. The Following User Says Thank You to Clunk For This Useful Post:
    BigRAWesty (24th July 2015)
  11. #1390
    That's a mimimal thing in the overall but yes. Much lighter
