Page 10 of 28 FirstFirst ... 89101112 ... LastLast
Results 91 to 100 of 280
Thread: Winnie's Warn hi mount rebuild
  1. #91
    It was $24.95 mate. That's nt what I need anyways. You don't need them either AB, you just need a couple of longer bolts.
    I need 1 or 2 of the square nuts used to hold the top hat on. Hey Winnie you haven't got any in that box of your have you?
    Hmm, I'm not sure Daz, I'll check in the morning and if I do then I'll bring them up to Licola for you
    MudRunnerTD (17th July 2015)
  3. #92
    It was $24.95 mate. That's nt what I need anyways. You don't need them either AB, you just need a couple of longer bolts. I need 1 or 2 of the square nuts used to hold the top hat on. Hey Winnie you haven't got any in that box of your have you?
    I know mate but they say RRP $45.
  4. #93
    334 Post(s)
    Oh it's for a Himount winch..... We can charge Drug Money!!!
  5. The Following User Says Thank You to MudRunnerTD For This Useful Post:
    AB (17th July 2015)
  6. #94
    Only $2.50 more than low mount.
  7. #95
    North brissy
    Umm go to the bolt shop? Any decent bolt shop should carry these.
  8. #96
    334 Post(s)
    Even the square nuts Matt?
  9. #97
    You can fit your filler to the side if you like. Plenty of room. You would have to use a syringe to fill it though? Do it to the front quarter of the casing. Alternatively you could drill and tap big enough for a filler on the side then instead of a plug bolt use a male/female reducer and fit a pnuematic fitting and your breather in the same hole.
    So do you mean that when you unscrew your breather then that becomes your fill hole?
  10. #98
    334 Post(s)
    Yes mate. But the air line fitting I used for my breather is too small so fitting that fitting into a reducer so it can thread into a bigger hole would work fine mate.
    So say you have a 1/2" hole tapped" fit a 1/2" to 1/4" reducing socket then fit a 1/4" air line. When you want to fill it just take out the 1/2" socket
  11. The Following User Says Thank You to MudRunnerTD For This Useful Post:
    Winnie (17th July 2015)
  12. #99
    Yeah cool, thanks I might play around with something
  13. #100
    North brissy
    Yeah the square nuts they should. Is there something special about the bolts?
