Yeah I think my Tap was labelled wrong.
Its a Nissan! =====> Its a Keeper!! ....... Got a TD42 in it BONUS!!....... I'm a lucky bugger! I've got 2 of em!
Rossco (17th July 2015)
It went straight in and didn't touch anything.
Do I need to shorten?
MudRunnerTD (17th July 2015)
So I've jumped the gun and wired everything up bar the front switches on the grille for the high mount.
If I run a single cable (or just run two) from the isolator in the cab and then splice off to both switches (in and out) on the grille to both the in/out wires right near the solenoid surely that is ok?
AB (19th July 2015)
Edit. Sorry just read your post again. Yes it will work but you already have a wire you can use at the front.
Take positive power from the LED light straight to those 2 switches in series. That power is isolated via the inside isolator switch. They just need a 12v supply they can send to the Solenoid for switching. Have another look at that drawing I did bud.
AB (19th July 2015)
