Results 31 to 37 of 37
Thread: Zd30 power loss.. cnt even pull skin off the custard..
  1. #31
    May 2015
    Mandurah
    I was having massive power issues and lots of black smoke, but it got pretty much all cleared when I blocked the EGR and fitted the dawes and catch can. I'm not sure what my boost was before all of that though as I got the gauge done at the same time. I just know now I'm not having the massive power lose i was having before, which wouldn't let me get above 80km/h. Now I can get up to speed I just can't keep boost. power still isn't great though.
  2. #32
    Expert mullet_hunter's Avatar
    Feb 2015
    perth.. norf of the rivr..
    have u checked ur turbo? my boost only drops off if i run it in standard form with no dawes etc... it was spiking had too... like if i put my foot down boost would drop but then i would put my foot off and then back on a little bit and boost would jump from say 5psi to 15psi.. boost drop off if you get off the gas is normal but not normal if its drop boost under load..
  3. #33
    May 2015
    Mandurah
    Turbo was replaced 9000k ago, it blew the day after I bought the vehicle.
  4. #34
    Feb 2015
    Did u disconcet battery fora hour or two when u changed ur maf? Ur egts should get hot pretty quick if you aint running much boost so keep in eye on that too...
    Sent from my SM-N915G using Tapatalk
  5. #35
    May 2015
    Mandurah
    Yea battery disconnected for about 1 and a half hrs
  6. #36
    Feb 2015
    How you going with your problems mate? Finally got aroundd to swapping out my maf sensor for another one... instantly fixed.. boostn 20psi and it pulls hrd... love it...
  7. #37
    Feb 2015
    Cheers mudski for the maf s3nsor to test out... cnt thnk u enough...
  8. The Following User Says Thank You to mullet_hunter For This Useful Post:
    mudski (18th July 2015)
