And re splice the rope, get a hook, grease some nipples, fix up the drain plug and put oil in![]()
MudRunnerTD (12th July 2015)
Hmm need a photo of that drum light, what type it is etc... Awesome idea! Not yours I'm sure![]()
Does it just come on when you switch power to the winch?
Rossco (12th July 2015)
It's just a little narva led light. I can't remember what type, Darren? It mounted perfectly underneath the light bar!
Does that have a magnet or double sided or something?
Yep I've got some of that stuff too, unbelievable stuff really!
Love the idea of the light though, you'll be bloody glad you did that the first time you winch in the dark
The light works a treat. I have had one on the back of the front number plate since Noah was a boy. It is just a Narva Truck marker light. It is powered by the winch isolator switch in the cab. When the isolator is turn on and the winch has power the light is always On. Turn the winch off and the light goes off.
The grill switches are water proof Momentary On switches mounted in the side of the left hand side headlight surround. The Navi can winch in and winch out when managing the spool without having to yell you instructions. You can also use these at home when responding your new rope and in a solo self recovery where you might have to be out of the vehicle. Power to these switches is on the same circuit as the LED Narva light above.
Looking good AB
Its a Nissan! =====> Its a Keeper!! ....... Got a TD42 in it BONUS!!....... I'm a lucky bugger! I've got 2 of em!
AB even came up with the idea of mounting the light under the light bar!!!! He knows Stuff...............all.![]()
