Page 5 of 8 FirstFirst ... 34567 ... LastLast
Results 41 to 50 of 79
Thread: NEV the nissan
  1. #41
    Patrol Freak Bigcol's Avatar
    Sep 2010
    Swan Valley Perth
    11 Post(s)
    looks good mate
    nice mods
  2. The Following User Says Thank You to Bigcol For This Useful Post:
    threedogs (12th July 2015)
  3. #42
    Heres some pics on my 3rd trailer [present] Built upside down for most parts.
    Hindsight which I have in spades I would have put the battery box up the back not the front like I did.
    No biggie,
    This is my 3rd trailer, I have access to a service body Which I may make a trailer from it ,not sure yet
    The draw bar has another piece that runs nearly the entire length.
    Also the draw bar had heaps of tabs welded to it for any additional boxes I want to fit
    I powder coated GQ Ti mags, the extra cab is another I made and sold
    FYI I used two sheets of 1/8th alloy checker plater in the build
    Painted the frame charcoal hammer tone
    I just love making things
  4. The Following 2 Users Say Thank You to threedogs For This Useful Post:
    Bigcol (12th July 2015), mudnut (12th July 2015)
  5. #43
    Im putting pics here for another member to view, scored these two tanks, they appear out of date,
    Any ideas on what to use them for other than testing and scuba diving Id like to hear.
    Im thinking these will hold a heap of air. I think they are made from alloy
  6. #44
    Smoker, bbq, little fire, rather large anal plugs Etcetera Etcetera Etcetera
  7. #45
    Hardcore jack's Avatar
    Ballarat Area
    26 Post(s)
    Hard to tell what size they are from the pics, could be 12 and 10 litres as they are the most common sizes. Should be some size info just above the start of the curve. Try a magnet to see if they are steel, if steel they may be able to be re-certified. It all depends on the condition inside, outside doesn't really matter and I've seen worse than that on dive boats. They can take a bit of a hammering as long as the valve is fine. If alloy then don't even bother to try and get them tested.
    If no one comes up with a better idea for them Clunk would probably take them off your hands as he seems to have a use for them.
    Jack
    2024 Isuzu MUX
  8. The Following User Says Thank You to jack For This Useful Post:
    threedogs (30th July 2015)
  9. #46
    Why the difference for the alloy tanks?
    latest stamp on the larger one is 08 and the smaller is 04
  10. #47
    Ballarat Area
    26 Post(s)
    They are a risk of exploding while being filled, most stores won't fill them even if they are 'in test' date. Check this link:
    https://www.worksafe.qld.gov.au/news...lloy-cylinders
    Jack
    2024 Isuzu MUX
  11. #48
    Bummer ,at least the valve on top is worth something.
    Might cut it in half long ways for some water dishes for the dog. lol
  12. #49
    My awning light just arrived, its a Kawell 18watt 60 degree beam spread.
    It will be hard wired with a dimmer and remote control as well.
    Die cast alloy body so very robust IMO cant wait to mount it,
    about 200mm long
  13. #50
    Expert Oldmate1's Avatar
    Mar 2013
    Brisbane. Wynnum West
    about 200mm long
    hi mate
    did you forget that you posted this same thing in two other places
    20013 ST Diesel manual, ARB delux bar with smittybuilt winch, Chinese roof rack, ipf spotties, tjm awing
    waeco cfx 50 and slide
