Page 2 of 2 FirstFirst 12
Results 11 to 19 of 19
Thread: Bloody limp mode again.
    Expert mullet_hunter's Avatar
    Feb 2015
    perth.. norf of the rivr..
    Try cleaning ur maf... I got the hpd maf housing and can see up to 27psi with no limp issues... Just recently It randomly started running crap.. Which I thought was a limp mode issue but ended up being leaking factory intercooler... He much boost are you seeing befor it goes into limp?
  2. #12
    476 Post(s)
    There was a post here recently about these HPD housings dropping the MAF voltage by .25V therefore going to limp mode and the fix was to get a chip. I'll try and find it
    Yes you are correct mate. The hpd housing work, really well. Ive have great results from mine. But i had a DP chip too....
  3. #13
    sunshinecoast
    3 Post(s)
    if your running a k&n filter you might be getting oil onto the maf sensor , jt just might need a clean , other than that perhaps it is spooling up a little too quick and might need the needle valve adjusting . hope this helps .
  4. #14
    Do you have a chip fitted ???
    I think scott at DP tweaked the DP chip to suit the HPD maf housing.
    But Im leaning towards a dirty sensor, only because it was fine before hand.
    Check your oil levels too the mighty ZD30 doesnt like being overfilled
  5. #15
    Patrol Guru Covo71's Avatar
    Dec 2012
    Coffs Harbour
    I am not sure if this is causing a problem but when looking for issues I found the pipe from the MAF housing to the turbo is perished and cracking. Can't tell but it may be sucking in air. Found these on fleabag but it says eliminates the air intake resonator. What does it do anyway? Anyone seen these or used? Looks like it should make airflow better with a smooth pipe. http://www.ebay.com.au/itm/Patrol-GU...item43de4ec057
  6. #16
    you will be sucking extra air, I've made a larger intake but yet to fit it.
    Replace the hose and any others you find , if ones gone others maybe as well
  7. #17
    476 Post(s)
    this is what i was talking about guys: http://www.nissanpatrol.com.au/forum...hlight=housing
    Might not be the issue but I thought it might help
    Read post #10 in this link. A chip might help. I ran a DP chip with the same setup as you with no issues. The intake pipe on my Di was cracked too, I was making a new intake pipe for it, but now the motor is coming out, for good....
  8. #18
    SUCH IS LIFE Maxhead's Avatar
    ACT
    Thats what i said in post 4 here
    ..........on the move
    ________________________
    ______ 2017 D-Max _______
  9. #19
    476 Post(s)
    It was a reference for the op....
    Not on the move.....
  10. The Following User Says Thank You to mudski For This Useful Post:
    Maxhead (22nd June 2015)
