Page 2 of 6 FirstFirst 1234 ... LastLast
Results 11 to 20 of 56
Thread: How to install a nutsert without using the tooling
    Banned
    Yes mate that would work on ensuring the bolt can pull up but I was referring to the actual nutsert spinning inside the substrate you are trying to lock it in to.
    They sometimes spin whilst your are trying to force the bolt up when spinning the nut so you may have to reef the bolt to one side or take it out and expand it a bit and ram it back in to the hole and start again.
    Yeah got that bit & the reason why it happens is the nut on the bolt grabs on one surface of the washer in turn the washer grads the face of the nutsert & as you turn the nut the whole lot starts turning together which means your winding the the nutsert back off the bolt at the same time.....
    By using 2 washers with a little grease in-between them should create a point of least resistance so in theory when the nut on the bolt grabs the surface of the washer & starts turning it, it should just slip against the second washer instead of turning the nutsert.
    As I said though its only "in theory" & if you play with these things at work I recon you could test out my theory for me & let me know if it works......
    Cheers Old mate.
  2. #12
    not bad old mate, not bad at all...lol...I'll have to try that out one day!!!
    Makes perfect sense and I reckon it would work a treat!
  3. #13
    Roofy, if your going to use these for a snorkel then I'll get some for you we have buckets of these to nustert into poles.
    remind me and I'll bring some nutserts, washers, split washers, torx bolts and torx key for ya too.
    Remind me though, I have a memory like a kicked in fish.
    Torx bolts are great, anti theft and look the goods!
  4. #14
    Patrol God Sir Roofy's Avatar
    TRAFALGAR VIC
    35 Post(s)
    Your a true gentleman ab
    it will put my brain in overdrive trying to remember what i have to remember lol
  5. #15
    Quote Originally Posted by roofy View Post
    Tell me about it, just shot you a PM for the list of things to remember...lol
  6. #16
    Good call mate not sure but they have been used on steel posts for decades with no rusting. Brass or nickel rings a bell but I'll have to double check tomoz
  7. #17
    Patrol God Finly Owner's Avatar
    Jul 2010
    Waterford West Qld
    So why can't you get nutsert tool? to use?
  8. #18
    Jul 2010
    Waterford West Qld
    AB why can you not get nutsert tool to use?
    And yes roof rack on rally car was nutserted on with fabricated brackets. (mate did his own and, I din't know until recently what they were called).
    "Specific Fasteners" Slacks Creek do carry full range of them.
    Tim
  9. #19
    Banned Bigrig's Avatar
    Oct 2010
    South of Brissy, QLD
    Are nutserts the same as rivserts?? Sorry for the dumb question, but I know how rivserts work, and plan on getting one to attach the camera to the car (and stuff to the trailer) and generally just to add to my collection of 'man toys'!!! LOL
  10. #20
    Plassy, yes the ones we use are brass which is good.
    Timbo, we do have nutserting tools but even those ones play up....They are cheap chinese ones we use and they constantly jam up. Sometimes the old trusty bolt trick just seems easier.
    Scotty, Yes mate I think a rivsert is exactly the same as a nutsert....Tomarrrtos and tomayyytos...lol
