Page 3 of 8 FirstFirst 12345 ... LastLast
Results 21 to 30 of 71
Thread: Losing boost..
  1. #21
    Good find MH a factory tigged IC is about 33% bigger than stock, so a small gain to be had.
    Have a look at an XR6 IC I think they would be very close to working .
  2. The Following User Says Thank You to threedogs For This Useful Post:
    mullet_hunter (3rd June 2015)
  3. #22
    May 2015
    Also what about the fuel filter. Last changed? When you get limp mode if you let off the go pedal and back on again it goes away.
    Hi Mudski, what you said above is what's happening to my year 2000 model Patrol. Do you know what is the fix on this problem?
    477 Post(s)
    Quote Originally Posted by Val View Post
    thats limp mode mate. Its usually caused by engine overboosting. The zd's ecu has an overboost safety precaution which is usually around the 16psi. Some times giving the maf a clean helps. Or replacing the maf, or fitting a dawes and needle valve. The dawes is designed so you can limit the maximum boost pressure so its below the limp mode over boost threshold.
  5. #24
    May 2015
    Thanks mate. I will clean and check MAF sensor then if it is working fine.
    Would you be able to send me a copy of Nissan Patrol Reference Document to my email address as I don't have enough post yet to download it? bon2x_77@yahoo.com
    Val
  6. #25
    May 2015
    Thank you for the info Mudsky.
    Hi to all,
    I want to share what we (me and my electronic engineer) did to fix this limp mode problem that we call without spending a single dollar. Since after checking all the sensors that I know (MAF, Engine TEMP and boost sensor) and proven that they are all working fine, I've tweak few times the variable turbocharger control actuator and that dropping of my boost disappeared. I’ve felt more power on the acceleration now even my boost goes up to 14 psi only.
  7. #26
    477 Post(s)
    Hi to all,
    Yeah thats also done here but for many its a pretty tricky job. Hence using a needle valve. Does the same as what you did but you can adjust it with minutes without touching the actuator. Get more boost into it mate and it will go even better.
    Cheers.
    Mark.
  8. #27
    May 2015
    Hi Mudsky,
    Thank for the advice mate. I like doing mechanical job (but I'm not experienced yet) so I think if I can get hold off on how to do this dawes and needle valve I will try it one day. How much do you think this dawes and needle valve kit that I need?
    Anyone from Bundaberg Queensland in this forum?
    Val
  9. #28
    477 Post(s)
    They're $154 (with EGR plate) plus $12, but member get 10% of the item price... $154 including post without the plate.
  10. #29
    May 2015
    Thanks mate. I'll get my boss (wife) to put a budget on this.
    Aug 2010
    Lower Blue Mountains
    17 Post(s)
    Val
    Bump for Val as post went into moderation due 2 email address.
    Val, type in "nissan patrol reference document" into google, first listing should be the Nissan patrol reference document hosted on another site that is a downloadable pdf file
