Results 1 to 10 of 13
Thread: Cracked diff case
    Expert Lawrence's Avatar
    St Thomas, Jamaica
    Cracked diff case
    Hi fellows. I have a crack on my front diff of my 89 gq wagon, which extends from the bottom of the pumpkin to a couple inches onto the right tube. It seems to be a fine crack but it's also quite noisy, like a creaking sound when the suspension is flexed. Is this repairable? If so, what's the best method to repair it? Can it be done on the car?
    1989 Nissan Patrol DX with the td42 (inline pump). No mods yet except black US 16x8 rims with 265 75 16 Ats
    Bugger. Got any pics? Find a new housing as it may well be bent. Consider fitting a GU front diff for a great Brake upgrade too. Bolts straight up.
    St Thomas, Jamaica
    Can it be welded?
  4. The Following User Says Thank You to Lawrence For This Useful Post:
    MudRunnerTD (14th June 2015)
    Aug 2010
    adelaide
    as mudrunner td said get a gu dif from wreckers as it will probadly be adout the same cost
    and very little down time with having to strip down thw old diff and take it somewhere to get welded
    and will it be straight when welded
    gu diff will go straight in and no down time patrol back on road by lunch time
    OH LEATHER IS NICE
    Hardcore macca86's Avatar
    Jun 2011
    Brisbane again! whoo!
    If you're handy with a welder degrease and wire brush the area then grind I shiny at the very end of the cracks drill them out with a 4mm drill then blaze it up no worries
    Such is the rule of honour.
    Patrol Freak Parksy's Avatar
    Jan 2013
    Nowra NSW
    5 Post(s)
    I found a complete housing for $20. If you look on Facebook people can't give them away. Welded some metal on mine so hopefully it doesn't suffer the same fate as yours.
    IMO and should be taken with a grain of salt.
    St Thomas, Jamaica
    Quote Originally Posted by macca86 View Post
    Thanks for the reply guys. The welding option seems like the best bet as any GU diffs would be extremely rare here. I am checking out the option of getting a used GQ diff as well. Can it be welded on the car?
    Legendary happygu's Avatar
    My rear diff on my GQ cracked the same way, on the original welding seam .... I was living in Alice at the time and didn't have much in the way of tools or equipment, so I just took it up to a good welding shop, and a couple of hours later it was all done - on the car ... probably cheaper than I could have done it for anyway
  10. The Following User Says Thank You to happygu For This Useful Post:
    Lawrence (14th June 2015)
  11. #9
    Quote Originally Posted by Lawrence View Post
    Oh sorry mate where is St Thomas??? As Macca says it will probably weld up as it looks like a plug weld now which is unusual. Drain the diff and drip to bare metal and weld on the car.
  13. #10
    St Thomas, Jamaica
    St Thomas in Jamaica, Mudrunner . Ok thanks. What type of welding would you suggest? A friend of mine says to use the electric welder (not that I know much about welding).
