Results 1 to 9 of 9
Thread: Gearbox Drain Plug
    Oct 2014
    Gearbox Drain Plug
    Hi just wondering if anyone might have had my problem? Just went to change oil in my GU and it appears that someone has locktighted the filler and drain plugs. Got filler out with great effort and force but drain plug wont budge. Tried several breaker bars with 4ft pipe to rattle gun etc, but wont budge. Don't wont break the housing as I have seen this happen. Any ideas?
    Did you try tapping it with a hammer to "crack" the seal,
    other than that maybe apply some heat.
    Previous owner may have even cross threaded it ggrrr
  3. The Following User Says Thank You to threedogs For This Useful Post:
    hotcahoona (12th June 2015)
    84 Post(s)
    I took my Patrol to a fleet maintenance
    place and got them to mig weld an old
    impact socket to the plug. Then they
    were able to apply enough force to crack
    the plug loose, after the heat had done
    its job.
  5. The Following User Says Thank You to mudnut For This Useful Post:
    Thomastown, Melbourne
    6 Post(s)
    Make sure you can get the filler plug undone first before draining....
  7. The Following User Says Thank You to Bloodyaussie For This Useful Post:
  8. #5
    He did..........
  9. The Following 3 Users Say Thank You to nissannewby For This Useful Post:
    growler2058 (8th June 2015), hotcahoona (12th June 2015), threedogs (8th June 2015)
  10. #6
    Oct 2014
    Thanks guys tried all that. leaving welding something onto plug as last resort.
  11. #7
    If tapping it hasn't loosened the seal, heat would be my next move, you're changing oil anyway.
    OOI is the plug looking square or do you think it may be cross threaded,
  12. #8
    Apr 2015
    I'll be watching this one as I have the same drama. I don't think mine were loctited in, I got everything open except the gearbox drain. Tried hitting it, heat, big cheater bar, no luck.
  13. #9
    Legendary 4bye4's Avatar
    Aug 2014
    Kingsley WA
    15 Post(s)
    Metrinch and heat. You don't have to use a gas axe, just an electric heat gun should release loktite. Use a metrinch socket idf the plug is damaged or rounded.
  14. The Following User Says Thank You to 4bye4 For This Useful Post:
    Swazi (28th February 2016)
