Page 2 of 8 FirstFirst 1234 ... LastLast
Results 11 to 20 of 71
Thread: Losing boost..
    Advanced shan-747's Avatar
    Aug 2013
    perth w.a
    How do you stop the limp mode from happening
  2. #12
    Aug 2013
    perth w.a
    And have a good look at every hose mate it might look food but moght have a little hole in it
  3. #13
    Quote Originally Posted by shan-747 View Post
    but fitting nads you can control the boost preventing limp or over boost mode
  4. #14
    Expert mullet_hunter's Avatar
    Feb 2015
    perth.. norf of the rivr..
    Ye will take off intercooler piping and hoses and check for any leaks.. it will boost upto 2000rpm but after that it drops off to nothing.. wouldnt be suprised if ive split either a hose or intercooler as i was running pretty high boost at arnd 27psi...
  5. The Following User Says Thank You to mullet_hunter For This Useful Post:
    threedogs (29th May 2015)
  6. #15
    Feb 2015
    Well I found time to look into why I'm losing boost.. Hoses and pipes looked alright as did intercooler... But thought I'd pull intercooler off to double check and next minute bubbles... Haha well I guess it was gona happen sooner or later running that much boost... Now time to get me a replacement...just gona go with a factory replacement with the end tanks tigged up...
  7. #16
    May 2015
    Mandurah
    You can remove the IC and check in water with a bike pump, make sure its dry before you replace
    it a hair dryer will help.
    Could you expand on how to do this a bit more please? Need to check my I/C.
  8. #17
    Feb 2015
    So you remove intercooler... tape up both ends... put it in a tub of water.. then preasurise it using either a bike pump or in my case an air gun making sure to only feather the trigger... then look for bubbles... if its hrd to push dwn into the water and wants to float or u cant see any visible bubbles its good.. or in my case if it bubbles and gets heavy frn water getn inside then shes leaking..lol..
    When testing i usually dip the flush taped end dwn into the water first and preasure the bent end up the top that way ur not putting the sensor into the water...
  9. The Following 2 Users Say Thank You to mullet_hunter For This Useful Post:
    bignev (30th June 2015), IronVoid (29th May 2015)
  10. #18
    May 2015
    Mandurah
    Excellent, thanks mate. Will check mine tonight, fingers crossed it's my problem as well, at least then I know what's going on.
  11. #19
    Feb 2015
    Good luck with ur intercooler mate...i went for a quick drive arnd the block... first time i seen my egts go over 400... so it does go to show that the more boost the lower ur egts...
  12. #20
    477 Post(s)
    With MR possible hose split or from running big boost split the IC open a bit more.
    At Mudski MH is running a HPD Maf housing, you mentioned a
    while back they should eliminate all over boost probs?
    The hpd housing doesn't eliminate over boost issues. It simply allows you to overboost.
    Good to see the op has found the issue.
    mullet_hunter (29th May 2015)
