Page 105 of 187 FirstFirst ... 103104105106107 ... LastLast
Results 1,041 to 1,050 of 1862
Thread: MudRunnerTD's GQ From the Ground Up
  1. #1041
    Boo!
    Now theres a name thats been missed
  2. The Following User Says Thank You to nissannewby For This Useful Post:
    AB (12th May 2015)
  3. #1042
    We don't hijack anymore plassy
    Just ate too many Cheezels...lol
    Is Ford better then Holden?
    How do I clean the maf?
    Will 35" tyres fit under a 2" lift?
  4. #1043
    476 Post(s)
    Cheezels are better the Twisties...
    No.
    Maf spray. Duh!
    Just....
    AB (12th May 2015)
  6. #1044
    22 Post(s)
    You will need castor correction for a maf sensor lift
    96 GQ coil/Cab
    08 G6eT
  7. The Following 2 Users Say Thank You to Ben-e-boy For This Useful Post:
    AB (13th May 2015), mudski (12th May 2015)
  8. #1045
    io you lot!!!
    Drop in for a coffee anytime Plas.
  9. The Following User Says Thank You to MudRunnerTD For This Useful Post:
    Plasnart (13th May 2015)
  10. #1046
    So I had s bit of a look through and there is a heap missing here.
    A couple of pics of the rewiring and cleanup
    From that ^^^^^^
    To that VVVVVV
  11. The Following User Says Thank You to MudRunnerTD For This Useful Post:
    Bloodyaussie (20th May 2015)
  12. #1047
    That's a clearer pic of where it started
  13. #1048
    Thomastown, Melbourne
    6 Post(s)
    So numb nuts where is the battery now and what sort is it?
    Any pic's of that.
  14. #1049
    The interior is out of the car at the moment allowing me access for sorting the air system ready for the Freespool for the winch and run all the 24v system. I gave run 70mmsq for the entire 24v system, sick!!!
    $45 crimper off ebay is wicked!! I had to buy a set of cable shears to cut the 70mm and they work a treat too
  15. The Following User Says Thank You to MudRunnerTD For This Useful Post:
  16. #1050
    I will now run only 1 x 12v battery in the car. It's under the Bonnett in the usual spot, it's a brand new Marine battery. All the stuff that was on the second battery is now wired to the fuse box you can see in the fire wall.
    24v system is s pair of Fullriver Gel batteries that were my pair under the bonnet before.
    I am fitting a 600amp continuos switch on the back of the centre console so I can turn the system off in an emergency.
  17. The Following 3 Users Say Thank You to MudRunnerTD For This Useful Post:
    AB (20th May 2015), Bloodyaussie (20th May 2015), Winnie (20th May 2015)
