Page 5 of 6 FirstFirst ... 3456 LastLast
Results 41 to 50 of 51
Thread: 12v oven sale today only
  1. #41
    477 Post(s)
    Quote Originally Posted by Mr-T View Post
    I looked it up and it's $49.98 not $18 and the listing says it's a stove but I guess it's probably good to keep the pies warm on a cold day so I'll go get one from my local Dickies.
    Cheers.
    Mate it will cook your pies....
  2. #42
    How will these go on a jump pack, with a 12v point? Will be ideal at the kids footy games.
    If you have a dual battery system and a power point 12v that is directly
    off the Aux battery Id use that, not any that require the ignition to be on.
    @ Winnie what size wire did you go up to 6mm???
    Also I think a merit plug would be better than a Cig job
    I think they would suck more than 10 ah
  3. #43
    Patrol God Sir Roofy's Avatar
    TRAFALGAR VIC
    35 Post(s)
    Want a good connection use an Anderson plug I used them on my oven and fridge
    don't have to worry about them coming loose and not connecting to power source
    when you hit corrurgations
  4. #44
    For a fridge yes a 50 amp anderson is the go, or a twist lock Engel/Baintech style mountable plug socket combo
    Cig sockets should be avoided at all cost for running anything whilst on the move, or stationary for that matter
    Try and source merit or the twist lock engel style, Merit have proved themselves to be up to the job for a positive connection.
    Plus run all these ovens etc from your Aux battery as well, thats why you installed it in the first place, to run add ons
    I have but dont use cig plugs for anything anymore, but when away sometimes you share gear so you need a compatable
    outlet. but not a fan of cig outlets
  5. The Following User Says Thank You to threedogs For This Useful Post:
    jay see (1st May 2015)
  6. #45
    Just did 3 pies and 6 mini sausage rolls in 90 minutes.
    Probably the best less than 20 I've spent
  7. #46
    Nov 2013
    QLD
    Is there any harm in running an oven like this from an anderson plug? Just have some spare andersons so like to use those rather then buying a merit plug
  8. #47
    Hardcore lucus30's Avatar
    Sep 2013
    16 Post(s)
    Quote Originally Posted by dannypatrol View Post
    If you are talking about these 50 amp Grey Anderson plugs and not the Anderson connectors ones they will be fine. I use Anderson Plugs for everything
    I even use them for my fridge
    Lucus30's 1999 GU ST TB45E
  9. The Following User Says Thank You to lucus30 For This Useful Post:
    dannypatrol (14th May 2015)
  10. #48
    X 2 on the anderson plug , see if you can get the TEE bar that you can bolt to them,
    helps when you want to get them apart, this one is on the wrong way.
    But you get the picture
  11. #49
    477 Post(s)
    Lol. Bit of an overkill for these ovens.
  12. The Following User Says Thank You to mudski For This Useful Post:
    Winnie (12th May 2015)
  13. #50
    Sep 2013
    16 Post(s)
    I agree but I just looove Anderson plugs
