Page 4 of 5 FirstFirst ... 2345 LastLast
Results 31 to 40 of 48
Thread: Usb charger to fit rocker switch slot
  1. #31
    Expert bishbashbosh's Avatar
    Nov 2014
    one last thing.. can you check out this thread and help me out so i can sort out the rear of my truck?
  2. #32
    BiPolar Fool BSRT.Beast's Avatar
    Apr 2015
    Keysborough
    4 Post(s)
  3. #33
    Nice fit was it into a switch slot
    Quote Originally Posted by BSRT.Beast View Post
    Did you wore that up through the ignition or straight from the auxiliary battery? If straight from the battery is the plug lit all the time? Is there a drain on the battery? Not much but potentially enough
  5. #35
    Seems it's ignition or always on.
    I guess you could ignition feed a relay so it's not always on but still drawing from sub.
    Nov 2014
    Waikiki, WA
    Bought this item from ebay: 251657096591. Installed it below and tapped into the aerial switch so it is isolated with ignition off.
    Came with an in line fuse.
    Unfortunately it is for European Nissan, the slot dimension were exactly the same however the locking device didn't hold it in place.
    Popped the dash facia off and secured it in place with super glue.
    Now have a charger for my Samsung Galaxy while on the road.
    2002 ST Coilcab, Chevy 6.5 V8 Garrett turbo, intercooled. 3.9 diffs, Cooper AT3 265/75/16.
    Trailstar Aquila 5.4
    http://s4.zetaboards.com/Gold_Detecting/index/
    http://www.youtube.com/watch?v=y7GCkFcHsh0
  7. #37
    Apr 2015
    Keysborough
    4 Post(s)
    Yes its into a switch slot the old GQ had one next to the heating slides.
    We piggy backed it of the cig lighter socket so it only works when the ignition is on.
  8. #38
    Well here ya go another option that I have just come across on fb..
    It seems both ports on this one are 3A.. which is a bonus..
    Patrol Freak BillsGU's Avatar
    Jul 2010
    Thurgoona
    7 Post(s)
    I purchased and installed one of these a couple of months ago. They look great and work great - except that I thought that they were also an on/off switch so you could use the rocker to switch the USB charger on and off. They are not and as I connect every accessory to the auxillary battery, I had to install a separate switch. Otherwise the USB would be permanently on. Anyway, I don't like the idea of connecting the USB charger to the ignition switch because sometimes I want to charge things when the ignition is off.
  10. The Following User Says Thank You to BillsGU For This Useful Post:
    BigRAWesty (30th October 2015)
  11. #40
    I have mine live to the Aux battery with no problems ,
    dont really have much room left for any on/off switches
