Results 1 to 8 of 8
Thread: Do these CV's look ok
    Feb 2011
    Shed
    45 Post(s)
    Gday folks, so the other weekend i changed swivel hub seals. Was cleaning everything up and have decided to change the wheel bearings. (next payday) So am cleaning and repacking my CV's with new grease. I found evidence of water ingress namely reddy brown grease. Now below are a couple of photos of what they look like. One of them the ballbearings have surface rust on em the others just stained. Do you rekon this is gunna be an issue? You wouldnt classify as a high speed joint as such would you? Ok its ur axle and that moves fast but is the movement of the CV action fast? Also theres Hot spots on both CV outers where the b allbearins are is this normal?
    Cheers all
  2. The Following User Says Thank You to growler2058 For This Useful Post:
    brynk (18th April 2011)
    The CV with surface rust on the balls I would be replacing, the rough surface will cause accelerated wear within the CV.
    The hot spots on both CV cases also has me a bit worried as this could be a weak spot. It's normal to see some heat discoloration on the CV case but it is an even color around the case, not hot spots lik you have.
    Tony
  4. The Following 2 Users Say Thank You to YNOT For This Useful Post:
    brynk (18th April 2011), Maxhead (2nd April 2011)
    Feb 2011
    Shed
    45 Post(s)
    MMMMMMM the discoloration is blued from heat at the exact location of each ball bearing. The old girl was originally a mine vehicle then worked in the bush on missions so i'm thinking corrugated roads for hrs at a time could something like that be the cause.
    Feb 2011
    Shed
    45 Post(s)
    Any idea on cost for new stub axles and cv joint???
    Feb 2011
    Shed
    45 Post(s)
    ok ebay from $50 bucks to $160 for the made in Japan version. Has anyone bought these. I'm assuming this would be an item of get what you pay for
    Banned Bigrig's Avatar
    Oct 2010
    South of Brissy, QLD
    Quote Originally Posted by growlers71gq View Post
    That's what I'd reckon - one of those 'under stress' components that I really don't want to trust to a company sourcing them from the cheapest bidder!
  9. #7
    Aug 2010
    Lower Blue Mountains
    17 Post(s)
    I would say you get what you pay for after looking at these prices
    http://www.marks4wd.com/products/CV%.../cv%20page.htm
    http://www.caloffroad.com.au/product...atrol%20GQ.htm
  10. The Following User Says Thank You to NissanGQ4.2 For This Useful Post:
  11. #8
    Feb 2011
    Shed
    45 Post(s)
    Quote Originally Posted by toddrhind View Post
    Sh!t Ay gunna be saving for a while, think the old ones are gunna get repacked and put back in for now, bumm@ ah well good practice
