Page 10 of 11 FirstFirst ... 891011 LastLast
Results 91 to 100 of 105
Thread: Yet more issues...
  1. #91
    Oct 2010
    Old Bar, NSW
    13 Post(s)
    Quote Originally Posted by Evo View Post
    and maybe check wheel bearings,
    If your doing the front bearing have a look at this,
    http://www.nissanpatrol.com.au/forum...-wheel-bearing
    Macca
  2. The Following 2 Users Say Thank You to macca For This Useful Post:
    Avo (24th April 2015), Evo (25th April 2015)
  3. #92
    Patrol Guru Evo's Avatar
    Jun 2013
    Lost somewhere in my own head...
    3 Post(s)
    Yes, threedogs, that's the tool I'm wanting...
    What meeting last night?
    That's no good with the back Stropp.
    Don't want you having a look if you aren't up to it mate.
    I could probably manage if I could get my hands on one of those tools for a few hours...
    Anyone have one I could borrow?
    Evo
    Cheers,
    Evo
  4. #93
    what size socket do you need,i could bring one up,,hey Evo i'll be in Bedfordale so I can come over sunday morning mate...no problem really..
  5. The Following User Says Thank You to Avo For This Useful Post:
  6. #94
    just read through,the biggest one we got is a 50mm and a 2"
  7. The Following User Says Thank You to Avo For This Useful Post:
  8. #95
    Patrol Freak lhurley's Avatar
    Oct 2011
    Brisbane. Manly West.
    You can get away with out using a tool. I don't have one nor do I plan on buying one. I use 2 long Allen keys or a punch if I have one handy. The screw ring (not sure what it's actually called) doesn't need to be super tight so it's fine to use a punch or something similar with a small amount of persuasion with a hammer.
    I really do hope it's something easy that you can fix yourself. Not much beats that satisfaction. All the best bloke.
  9. The Following User Says Thank You to lhurley For This Useful Post:
  10. #96
    Jun 2013
    3 Post(s)
    Thanks for the idea lhurley.
    WA489 it's not a socket, it's the tool with the 2 pins for adjusting the bearing adjustment ring.
    Thanks though.
    See if I can get a look in the morning. Some prick broke my antenna in a shop car park so going to try fix that too...
    Evo
    Cheers,
    Evo
  11. #97
    Jun 2013
    3 Post(s)
    And with the bearings, say I nip up where I have eliminated play but the lock ring holes don't line up, do I tighten the threaded ring to the next available hole or slacken off to the previous hole?
    Evo
    Cheers,
    Evo
  12. #98
    Oct 2010
    Old Bar, NSW
    13 Post(s)
    If by tightening a small amount more I would head that way, if its not far the other way give that a go.
    Personally using the correct tool causes the least problems, no damage, deformation of the holes or risk of a sliver of metal being dislodged.
    At a pinch using two pin punches or even the blunt end of drill bits and a large screw driver to wind it up tight would be better than using a hammer and punch, but you have to use what you have.
    Good luck.
    Macca
  13. The Following User Says Thank You to macca For This Useful Post:
  14. #99
    I would add a little more load if the holes don't align.
    Take your time make. It's very fascinating pulling the hubs apart, you'll be thinking "is that all that turns my wheels"...
  15. The Following 2 Users Say Thank You to BigRAWesty For This Useful Post:
    Evo (25th April 2015), macca (26th April 2015)
  16. #100
    Jun 2013
    3 Post(s)
    Ok, gave it a go.
    Ended up somehow slipping and ended up on my arse on the driveway, but that's another story...
    Nipped both sides up, pretty much one hole tighter.
    Not sure if it's just me, but I can't say I've noticed a difference...
    Evo
    Cheers,
    Evo
  17. The Following User Says Thank You to Evo For This Useful Post:
    BigRAWesty (2nd May 2015)
