Page 2 of 2 FirstFirst 12
Results 11 to 19 of 19
Thread: wiring kit
    Hardcore lucus30's Avatar
    Sep 2013
    16 Post(s)
    Good point.
    The cable has to handle the D250 current as well as the Smart Pass so the load will be considered to be in excess of 100 amps.
    If that SCA product is 4 AWG I agree it will be large enough but the label says "4 gauge" not 4 AWG, 4 SWG or whatever which is suss.
    I am guessing that if the fuse being supplied is only 60 amp then the cable isn't 4 AWG.
    (Supply cables should be fused to reflect cable rating not the load of the device)
    If an accessory is rated up near the wiring rating then awesome result and one fuse solves the issue otherwise Accessories or devices should be fused seperately and as close as reasonable to the Accessory.
    If it is indeed genuine 4 AWG cable and SCA have, for some reason, only put in a fuse that is about 1/2 what the cable will carry then, yes, it will be OK for a Smartpass/D250 if the supplied fuse is chucked and a 150 amp jobbie used as per Ctek recommendations
    OK yeah I was just assuming 4AWG but I guess you could be right it doesn't state it is
    Lucus30's 1999 GU ST TB45E
  2. #12
    Expert Malgreen's Avatar
    Yulara
    there was more info on the back of the label,, cant look now as i am 1400km away and wont be back until early May.
    the cable is rather thick, but if i cant get the correct info for it i will just use 4awg wire with a 150amp breaker..
    just would have liked to use this as its got the battery already soldered on and i don't have a decent soldering iron to do the job..
    i was trying to avoid the cost of one for a once off job.. oh well...
    as for the wiring kit, i will use it for what it was meant for, wiring up an amp once i get one..
    thanx anyway guys
  3. #13
    Sep 2013
    16 Post(s)
    I'm sure a auto elec wouldn't charge much to crimp a couple of cables for you.
  4. #14
    Yulara
    yeah thats true,,
    ok,, but i have been looking around google about this as i have had a bit of time today,,
    looks like 4 gauge is pretty much the same as 4awg..
    but i think i will start from scratch,,
  5. #15
    Quote Originally Posted by Malgreen View Post
    yeah thats true,,
    Nah mate, use it.
    It will be heaps good enough for a D250
  6. The Following User Says Thank You to the evil twin For This Useful Post:
    Malgreen (19th April 2015)
  7. #16
    Yulara
    yeah thanx Evil..
    now just to work out how to mount the bloody thing,,,lmao
  8. #17
    yeah thanx Evil..
    I mounted my C250Dual on the steel plate which is just behind the Aux battery. I think this plate is there for models with ABS, mine doesn't have it...
  9. #18
    Yulara
    not a bad spot, i will look at mine when i get home.
    but i think there is a heap of pipes there for the ABS .
    i was going to back a bracket on the fire wall but not sure about attaching it as i have no idea whats behind that panel..
    there are 2 or 3 bolts that have nothing attached to them on the engine side of the wall but i dont know if i can use then or that they hold some thing else in place on the other side...
    i could drill a small hole and stick a probe in to see,, maybe,,lol
  10. #19
    I think the abs module is on the other side of the plate I mounted the ctek too. To make things easier I removed the entire plate and mounted it then wired it up.
    The only issue here is heat. These dont like heat. So I have ordered some heat shield for the battery and the ctek. This should help a little.
    I may even still move it to under the dash on the lhs but thats on my list of things to do.
