Results 21 to 30 of 31
Thread: Getting a drive train clunk when turning.
    Yeah and a bit harder to repair than body mounts!
    Ooh yes. . . A bit more expensive too i would say.
    Yeah pretty much the same as putting in or pulling out body lift. Need to take all bolts out and Jack the body up a little. Not real hard just a bit of a pain.
  2. #22
    Only took me and a mate about 2 hours to take my body lift out so it's probably a job I should do sooner rather than later....... nah it can wait
  3. #23
    82 Post(s)
    If your gunna do the body mounts, undo the top radiator mounting screws, so you don't flex the radiator when jacking up the front of the body.
  4. #24
    82 Post(s)
    I think it is the diff because I did
    a tight U turn and it felt fine
    until one of the tyres squealed
    a little bit
    as the clunk happened.
  5. #25
    Oct 2014
    Swan Valley
    G'day, all.
    Recently when I do a right turn at an intersection (sealed road in 2H), there seams to be some slackness in the drive train which gets taken up as I accelerate. It doesn't do it when making a left turn. Any ideas where to start looking for the cause? The engine and gear box mounts are ok.
    It sounds like you have 2 separate issues. 1stly, your rear diff is worn & has too much backlash, which is why the "slackness" gets taken up when you accellerate. 2ndly the clunk is most likely your panhard rod- either the bushes or where it mounts onto the chassis. Check that the bolt eyelet on the chassis is round & not egg shaped & torque the CRUD outa that bolt. I mean SWING off it!!! Also check your radius arm bushes. They'll cause this as will worn tie rod ends.
  6. The Following User Says Thank You to Sharky1 For This Useful Post:
    mudnut (12th May 2015)
  7. #26
    82 Post(s)
    I jacked the rear axle up,
    undid the tail shaft from
    the flange, fitted the
    flange tool I made last
    year and used a long piece
    of pipe on a breaker bar to
    torque the nut up about an
    eighth of a turn. I also used
    a tyre lever to recheck all of
    the rear bushes. I also pulled
    the top panhard bolt out and
    checked the bolt holes. After
    re-torquing the nut super
    tight I took the Old Trol
    for a test run to a court and
    did a few figure eights.
    There is a definite
    improvement. Some
    of the bushes are getting
    long in the tooth and will
    be replaced when cash is
    available.
  8. #27
    82 Post(s)
    With the help of a
    mate, who owns a
    hoist, I torqued the
    flange nut another
    eighth of a turn.
    The diff now has a
    slight breakaway
    torque, which is what
    the manual recommends.
    The test drive was
    smoother too.
  9. #28
    82 Post(s)
    I found that the lefthand side engine mount had also let go. The clunk has almost completely disappeared since renewing the mount. The diff probably needs to be checked properly. When finances permit, I would like to get the diff shimmed a bit tighter.
  10. #29
    @ MN I have laser cut washers if the body mounts are out of round, [weld on]
    panhard mount on the chassis
    Have all the "Clunk" jokes been done???
  11. #30
    Dont worry fella, I haven't completely disappeared..... I'll always come back to haunt you when you least expect it
    Not at all mate, I'm sure there's plenty more to be had
  12. The Following 2 Users Say Thank You to Clunk For This Useful Post:
    BigRAWesty (17th December 2015), mudnut (17th December 2015)
