Page 3 of 3 FirstFirst 123
Results 21 to 26 of 26
Thread: ABS/VDC warning lights when hard braking
    SUCH IS LIFE Maxhead's Avatar
    ACT
    How far off centre is your steering wheel? After replacing the panhard rod, tie rod and steering damper it sits 90deg out
    What lift do you have? 2" TJM Gold
    I don't see how the steering wheel not sitting straight can be the cause, if it happens when stationary.
    Mine will occasionally bring on the lights when I'm traveling on dirt roads at speed. Once I cycle the ignition, lights turn off.
    see above Rod
    Another thing that will happen if I dont press the brake hard to bring the lights "ON" is if I drive and turn my steering wheel the left front wheel starts locking up or so it feels like it(like stability control kicking in)
    ________________________
    ______ 2017 D-Max _______
  2. #22
    Banned
    Apr 2011
    Greenbank QLD
    25 Post(s)
    90degrees thats a mighty effort. Vehicle speed is another input for VDC/ABS. It shouldn't cause a fault when stationary.
  3. The Following User Says Thank You to Yendor For This Useful Post:
    Maxhead (2nd April 2015)
  4. #23
    ACT
    It was only about an eight out before I replaced the above components, but after it was worse and I have no idea why. Anyway I will replace the drag link with an adjustable to get it right. Once I get the vehicle back after they do the recall I'll try the same with holding the steering wheel straight
  5. #24
    Banned
    Apr 2011
    Greenbank QLD
    25 Post(s)
    Yeah, I think thats your next step. It will be interesting to see how it is after you replace the drag link.
    What recall? Panhard nut?
  6. #25
    ACT
    Draglink will be ordered as soon as I find some coin, bit broke ATM.
    Yeah, I never took it in as I thought it was a joke of a recall but I suppose they will fit the bit of space age engineering onto the nut...lol
  7. The Following User Says Thank You to Maxhead For This Useful Post:
    Yendor (2nd April 2015)
  8. #26
    ACT
    Forgot to update till I saw another thread...OOps
    Anyway, I picked the vehicle up from Nissan and after them telling me the whole time my steering wheel was out causing the issues the actual problem was just a brake fuse apparently!
    They replaced the fuse and no issues for the past two weeks:) Happy chappy, although I have only driven it twice...LOL
    Anyway happy for now
