Page 2 of 2 FirstFirst 12
Results 11 to 17 of 17
Thread: TD42i EGR blocking & all that stuff.
    Ballarat, Vic
    178 Post(s)
    Quote Originally Posted by Kempy View Post
    Just out of curiosity but why does he pull the butterfly out?
    Once the egr valve is blocked the butterfly becomes superfluous & only serves to create a restriction to air flow. That’s as I understand it, others might offer more detail.
  2. The Following User Says Thank You to Cuppa For This Useful Post:
    Kempy (1st April 2015)
  3. #12
    Patrol Freak Bigcol's Avatar
    Sep 2010
    Swan Valley Perth
    11 Post(s)
    well, after reading TimE write up.........
    bugga me, I dont have to worry about it
    mine was a NA and I added the Turbo & intercooler from a 2006
    so the butterfly is already disconnected and I dont have the EGR to blank off either
    mine is wholey and solely NON computerized, so they were never connected up
    cheers anyway Cuppa
  4. #13
    177 Post(s)
    Bit of a thread dig...
    Will be doing the entire removal this weekend. Well, whats left of my EGR system, which is basically the heat exchanger, associated coolant lines and the pipe at the back.
    I have found this kit at Patrolapart. (pic below)
    Everything is very straight forward. Only one thing I'm confused about.
    The coolant T piece at top of motor, is removed and a in-line pipe is inserted. (pictured below)
    But...
    What happens to the coolant barb on the block ?? How is it blanked off? It does not appear to be in the kit.
    @nissannewby
    477 Post(s)
    I think its a threaded port into the block. You would remove the fitting and put a blanking plug in there. As for the size. I am not sure. I can have a look on the Nissanfast parts program tonight to see if it tells me anything.
    Hodge (14th December 2018)
  7. #15
    177 Post(s)
    Newby got me sorted mate. It's a blanking plate , after you take off the barb plate. Just picked the kit up from Patrolapart before.
    Taking off the pipe at the back will be the biggest challenge. It's a contortionist challenge.
  8. The Following User Says Thank You to Hodge For This Useful Post:
    mudski (14th December 2018)
  9. #16
    Jul 2012
    what this have to do with anything
  10. #17
    483 Post(s)
    Quote Originally Posted by Donnie View Post
    Welcome aboard Donnie mate?
