Page 4 of 5 FirstFirst ... 2345 LastLast
Results 31 to 40 of 46
Thread: CTEK D250S Dual
  1. #31
    476 Post(s)
    Its about two years old. The only charger I have is an Arlec 8amp charger with boost mode on it...
  2. #32
    476 Post(s)
    Could I use 6mm solar cable for the ctek? Thats all I have on me...
  3. #33
    For what to where over how far?
    (Should be more than adequate... just checking)
  4. #34
    476 Post(s)
    Ok I have the ctek mounted right next the aux battery. I need to run a cable from the starter across to the ctek, then the ctek to the aux battery and the earth of course. I will worry about the solar connection later...
    If its not sufficient I will get some larger gauge cable later.
  5. #35
    Ok I have the ctek mounted right next the aux battery. Do I need to run a cable from the starter across to the ctek, then the ctek to the aux battery and the earth of course. I will worry about the solar connection later...
    No worries... 6mm will be oodles for that
    mudski (31st March 2015)
  7. #36
    476 Post(s)
    Sweet! Gir it mounted nice and close.
  8. #37
    ... should add that the Ctek will start to reduce power output at temps over 50 deg so under the bonnet isn't exactly ideal but life is a compromise and they need to go where they need to go
  9. #38
    Awesome... now, take 10 minutes to neaten up your battery connections as well, slacko
  10. #39
    476 Post(s)
    are the temps monitored by that lead? I though of running it toward the front next to the headlight... That should keep the sensor at a cooler temp. I have in mind to make up a heat shield for the battery and ctek. Maybe even one of those beanies for the turbo like TD used.
    Yep thats the next part. New battery tomorrow, I just need to move the vacuum canister and re-route the hoses to it, then shift the catch can, then I can make up a mounting plate for the 4way relay housing and 16way fuse housing. Its getting quite bad under the bonnet. I wish I had a daily driver so I could just park this thing, and rip the entire loom out and make a new one. You should see the other side behind the headlight! Running Projectors with HIDs, angle eyes and devils eyes, plus all the other shite, its really bad.
  11. #40
    476 Post(s)
    Well its all in and connected. I started the car up, lights came up on the ctek, the power light, the alternator light and the service battery light. I checked the charge voltage and the crank battery is getting a charge but the aux isn't. new battery there so maybe its charged enough sitting at 13.5V.... I can't see anything in the three whole pages about voltage cut-off etc etc..
