Results 11 to 20 of 21
Thread: New HPD MAF housing put in!
    http://www.ebay.com.au/itm/161362145...%3AMEBIDX%3AIT
    Was toying with the idea of using this housing as its 6mm bigger than OE
  2. #12
    477 Post(s)
    Providing your maf will fit into this housing and you can adapt this to your vehicle, there is no reason why it would not work. I saw these a while back before I got my HPD housing. Laziness got the better of me though...
    would you get much more from a chip,
    how about a re map seems to be better than a chip
    Edit.. the Hume hwy out of Melb is 110 kph max on the way to the Murray.
    so for me anything around 12-15 psi would make me happy
    Depending on chip, the DS chip does the same as the HPD housing, but in the electrical side of things, and I don't think you can remap the DI ecu. I think...
    I'm going up the Murray on Thursday with the camper in tow. At 110k, on the flat, I usually sit on around 18psi.
  3. #13
    Expert Paule's Avatar
    Jan 2014
    Sandhurst
    Do you guys know what the ID is of the hpd housing?
  4. #14
    477 Post(s)
    Quote Originally Posted by Paule View Post
    74.3mm.............
    Paule (29th March 2015)
  6. #15
    Jan 2014
    Sandhurst
    74.3mm.............
    Thanks mudski
  7. #16
    477 Post(s)
    No problem.
  8. #17
    Patrol Guru Covo71's Avatar
    Dec 2012
    Coffs Harbour
    Just took it for a decent run and some hills and it is spot on. Maxing at 19 to 20psi. Not sure why it is so different but don't really care. I will hit some tracks next week down at Lithgow so see how it goes. Cheers
  9. #18
    477 Post(s)
    Good to see mate. You can now kiss limp mode goodbye, forever.
  10. #19
    Would be easy enough to whip up a new MAF housing, OD is 3.25" so
    Ive ordered a 3.25" to 3" reducing hose, That Skoda housing has
    a maf Hole in it is about 34mm approx. Skoda maf housing 1.7mm bigger than HPD
    Or skim 3mm out of the OE housing
  11. #20
    Patrol Guru Rock Trol's Avatar
    Mar 2013
    NE Melbourne
    Is this mod only if the car is going into limp mode? Would a CRD benefit from using it?
    Looking on the HPD's web site they only have a model for pre Aug 2004 and Aug 2004-2008. This would include early CRD's but not the bulk of them. The site only mentions ZD30DI models, not CRD. My car is a 2007 and I suspect its using the same housing as the DI's but I do not have any limp mode issues.
