Page 16 of 30 FirstFirst ... 1415161718 ... LastLast
Results 151 to 160 of 294
Thread: 04 gu bus...
  1. #151
    Expert mullet_hunter's Avatar
    Feb 2015
    perth.. norf of the rivr..
    Ye bit gutted.. but hopefully can pickup a 2nd hand injector pump on the cheap... otherwise save up towards a new baileys pump...
  2. #152
    Im a firm believer in that good things come to good ppl.
    and you MH IMO are good ppl, it'll work out without
    hurting too much.$$$
    mullet_hunter (24th March 2015)
  4. #153
    Legendary big_fletch's Avatar
    Oct 2010
    Tatura VIC
    Couldn't help but notice in one of your pics that the heat switch is on near the switch you put in on drivers side, also known as idle up switch? This isn't still on is it? Just throwing it out there for the high idle problem?
    Fletcha
    Qualified Auto-Electrician
    Apprentice Sparky
    Dont own a Patrol or any 4WD at the moment, hopefully will change into the future
  5. #154
    Feb 2015
    nah bud def not the high idle switch.. thought it might be related but seems to be the injector pump... but on a better note.. managed to find someone who's got a left over zd30 injector pump after doing a 4.2 conversion... after a bit of chit chat i was offered it for $200.. hoping to pick it up in the next week or so... thats got to be a win...been told its done 220k and was working sweet before conversion so at $200 if it doesn't fix my problem i guess I'm not that much out of pocket.. as my diagnostics cost more than that alone.. lol
  6. #155
    Oct 2010
    Tatura VIC
    That's a very good end result I reckon, Can't go wrong with that. Hopefully it fixes it
    Apprentice Sparky
  7. The Following User Says Thank You to big_fletch For This Useful Post:
  8. #156
    Feb 2015
    if it saves me 4k i will be a happy man... heard removing and replacing the injector pump is a pretty big job so I'm researching my little heart out.. lol.. plus if i get stuck got a good mate who will help me out.. i always belive in giving everything a crack urself before forking over hard earned...the only way to learn imo..
  9. #157
    Feb 2015
    ok finally finding time to fix the injector pump in my bus... any tips before i start? also u basically have to pull half the engine apart to get at it so which would be easier pull the engine out or just work on it with the engine still in the bay? take tyres off and put bus on jack stands? or put bus on ramp and work from underneath? cheers and thanks in advance...
  10. #158
    Feb 2015
    Solid day of wrenchn... another solid day tomorrow id sayy...
  11. #159
    Feb 2015
    180k worth of caked up shite.. haha
  12. #160
    Feb 2015
    For all u fallas who think its a carnt ovr job to get the heat shield off... thats nothing compared to getn the injector pump out.. haha.. had to take out radiator shroud.. tappet cover.. vacume pump.. power steering.. main battery.. intake manifold.. intercooler.. glow plug seals.. frnt timing case/chain... cut cable ties off loom to get it out the wayy... injector lines.. egr assembly.. haha pretty much strip everything except exhaust manifold n turbo..
