Page 15 of 30 FirstFirst ... 1314151617 ... LastLast
Results 141 to 150 of 294
Thread: 04 gu bus...
  1. #141
    Just found a 383 stroker kit for $800 from the states delivered.
    My son is giving my cast iron 350 motor to me, not for the patrol though
    maybe an early one tonner etc lol
  2. #142
    Expert mullet_hunter's Avatar
    Feb 2015
    perth.. norf of the rivr..
    Talked to the bloke at workshop.. Apparently a lift pump will do stuff all... So looks like il just have to deal with the high idle n hrd startn for awhile... Also wired up my reverse lights but it didn't make me feel any bettr...
  3. #143
    477 Post(s)
    Quote Originally Posted by mullet_hunter View Post
    It may. But I would be doing it if it were me.
  4. #144
    Feb 2015
    Ye I might have a go at fitting lift pump... Also might be worth trolln gumtree for a cheap 2nd hand injector pump or blown zd30 I can take ip, turbo, ic and injectors off...
  5. #145
    Patrol Freak Bigcol's Avatar
    Sep 2010
    Swan Valley Perth
    11 Post(s)
    I have found a hell of a lot of "mechanic's" dont know diddly-squat about 3l patrols
    I think the 2 biggest things for you to investigate is
    1) put in the lift pump.......... for ALL the reasons in Big_Fletch's thread - very logical and simple
    2) have a look at fitting a second or even a third extra Earth from the motor to the chassis & gearbox to the chassis - worst thing about Patrols is Earths
    my old GQ used to play up in Gas, sometimes start, some times not, sometimes run great cold, but not hot, sometimes run great hot, but not cold, relays get power sometimes, sometimes not..... etc
    ........ could never work out why, one day, while underneath running some cable for Anderson plug, I thought......."mmmm I might put in an extra earth from Gbox to Chassis while I'm here" - well bugger me with a stick, the Gas stopped playing around
    and ran beautifully all the time
  6. The Following 2 Users Say Thank You to Bigcol For This Useful Post:
    4bye4 (23rd March 2015), mullet_hunter (24th March 2015)
  7. #146
    Beginner yeah_m8's Avatar
    Lancelin
    I had the same problem, ended up tearing a part of the trim to which this didn't help at all.
    It came down to constantly opening and closing locking mechanism and opening an closing door mechanism at the same time until it opened, took about 10mins of doing this before the door came free.
    Once opened and removing the whole lock mechanism, I found a small part broke inside, a call around to local parts supplier almost gave me a heart attack, I swear they quoted me prices for gold plated locks, after some deep thinking and a can of ale, I ended up heading to Supercheap and buying some small bits an pieces for less than $10, dismantled, replaced bits, reassembled, installed and the lock is working perfect, it will out last all the other locks.
    Once I figured out how and what needed to be done, it's a piss easy job now.
  8. #147
    Feb 2015
    its been diagnosed by two diesel specialist both are telling me its the injection pump.. will try a lift pump, try another couple earth straps but def not keen on paying the 4 plus k to get it fixed... i looked at baileys diesel group... they can do a change over unit for $2350.. this might be an option if i cant find a cheap 2nd hand unit..
  9. #148
    the carter pump is at least cheapish to do and what have you to lose nothing.
    but gain a constant fuel pressure
  10. #149
    Feb 2015
    Hookd up lift pump late last night.. no improvemnt... u win some.. u lose some.. stil not ready to giv up on her jus yet tho..
  11. #150
    Bummer not good mate
