Page 6 of 8 FirstFirst ... 45678 LastLast
Results 51 to 60 of 79
Thread: The will it work thread?
  1. #51
    477 Post(s)
    Quote Originally Posted by doka404 View Post
    Got me thinking now..think the Superior rear pinion guard would be just as good..
    Harris Hardcase do a rear pumpkin protector. Just waiting for his to get of his rrss and make one for the H260 diff.
  2. #52
    Something like what is on the Currie Rock Jocks?
    Attachment 56278
    you need a bash plate that will allow you to slide not the most difficult thing to make
    when I get around to it Im welding skid plates to the front pumkin out of some 12 flat
    will be a bit of mucking around cutting all the bits to shape but will be worth it in the end
    Gecko17 (18th March 2015)
  4. #53
    Apprentices Rule!!! Punderhead's Avatar
    Nov 2011
    Toowoomba, QLD
    you need a bash plate that will allow you to slide not the most difficult thing to make when I get around to it Im welding skid plates to the front pumkin out of some 12 flat will be a bit of mucking around cutting all the bits to shape but will be worth it in the end
    Draw it all up and get it laser cut? Outback ideas skid diff plates? Or would you stick to recovery points.?
    GO HARD OR GO HOME!!!
    My rig HERE http://www.nissanpatrol.com.au/forum...Moneypit-89-GQ
    WARNING: Towballs used in a recovery can and DO KILL people!!!
  5. #54
    nah Harris already do a bash plate mine will be a weld on job, probable to withstand comp truck style punishment.
    Anything is possible if enough like the design
  6. #55
    @ Mudski Ive found a uni style MAF housing at 76mm in diam, but more on that later.
    IYO do you think my full stainless steel intake pipe will flow more air than the HPD MAF housing with OE piping?
    Or anyone for that matter will it work better ,the same or,,,,,,???
  7. #56
    84 Post(s)
    I see that they're now selling production cars with supercharger/turbo combos. That would give you a perfect torque curve.
  8. #57
    Patrol Freak Gecko17's Avatar
    Mar 2013
    Isn't that what they achieve with twin turbos? One high pressure, one low?
    2006 Ser IV GU, 6.5l TD V8 Chev with 4spd Auto, 3in Lift, 35in Kumho's, 12000lb winch, Nissan snorkel, Diff breathers, lightbar + Lightforce HD spots on roofrack. Built to go bush.
  9. #58
    84 Post(s)
    I think it is a gimmick, but it would eliminate turbo lag.
  10. #59
    Forced induction from idle, then the top end of a turbo. Very nice.
  11. #60
    Mar 2013
    So is the supercharger redundant at the higher revs?
