Page 100 of 187 FirstFirst ... 9899100101102 ... LastLast
Results 991 to 1,000 of 1862
Thread: MudRunnerTD's GQ From the Ground Up
  1. #991
    334 Post(s)
    Quote Originally Posted by dakka1 View Post
    hey dude what page of this MASSIVE thread do I go to for the high mount install. im just trying to see where and what and how when it comes to water or oil lines and drain etc
    Lol. I assume your talking aout the Himount winch. The first group of Himount winch pics would be in the first 10 pages I reckon depending on how many posts per page your set at. When I started the thread I was basically finished the car so rolled them all out quickly. The winch was done up first then.
    I am currently rebuilding the winch again and have it out of the car and completely stripped down. Let me know what you want pics of and I will take a couple for you. The cases have just been painted and I have not reassembled it yet.
  2. #992
    334 Post(s)
    Next got started on the winch. I pulled it to bits on the bench in the shed to give it a good clean out.
    I used this link for a great writeup and how to ==> http://www.pirate4x4.com/tech/billavista/8274/
    Then i went about renovating what needed to be done. I Painted the casing using a Charcoal Hammertone paint out of a can
    I tapped the casing to run Air lines to pressurise the case for Bog holes etc. You can see also that i used some of that PVC liquid tape on the terminals thinking that i could trim up the mess when dry => NO YOU CANT!!! so after this pic i went and got a very fine brush and neatened it up allot.
    I reckon it looks great.
    Mounted it back up into the newly painted bar and fitted the air lines
    See on the back of the numberplate i have fitted a white LED marker light that is switched with the winch isolation switch in the dash and lights up the winch whenever power is connected to it. F*#king awesome at night for winching.
    Attached my home made Nylon Fairlead and Bob's your Aunty.
    From this >>>>
    To this >>>>>
    Mounted up my Lightforce XGTs that i converted to HID and wound on the plasma and ready to go!!
    Post 44 for a start. Also post 43 had a couple. As I said though I have it on the bench and can take whatever else you want mate.
  3. #993
    Jun 2014
    shit sorry dude was meaning the turbo. sorry should have been more specific
  4. #994
    334 Post(s)
    Hahaha. Yeah had a feeling you might have been. My turbo is a low mount and is a full MTQ system. I had it fitted by a shop though way back when. If your chasing pics and info on a Hi Mount Turbo setup your best to ask Bloody Aussie as he has just fitted one to his new TD.
  5. #995
    Expert Majestic's Avatar
    Oct 2014
    Central West NSW
    Looks like MudRunnerTD's GQ has made it's way onto Facebook courtesy of 4WD TV.
    https://www.facebook.com/4wdTV/photo...type=1&theater
    Owner of 1984 SD33T MK Patrol
    Owner of 1989 TD42 GQ Patrol
    Previous Owner of a 1988 TB42 DA Maverick
  6. The Following User Says Thank You to Majestic For This Useful Post:
    MudRunnerTD (14th March 2015)
  7. #996
    Apprentices Rule!!! Punderhead's Avatar
    Nov 2011
    Toowoomba, QLD
    Quote Originally Posted by Majestic View Post
    Looks like MudRunnerTD's GQ has made it's way onto Facebook courtesy of 4WD TV. https://www.facebook.com/4wdTV/photo...type=1&theater
    Yep saw that. I can now stalk all of your Facebook profiles, it's not that hard to do some patrol matching to names!
    GO HARD OR GO HOME!!!
    My rig HERE http://www.nissanpatrol.com.au/forum...Moneypit-89-GQ
    WARNING: Towballs used in a recovery can and DO KILL people!!!
  8. The Following User Says Thank You to Punderhead For This Useful Post:
    Majestic (14th March 2015)
  9. #997
    334 Post(s)
    I must be famous!!!
  10. #998
    I must be famous!!!
    Yea...
    Sure......
    Ay I was thinking the other day about your gearing issues with the gu and 35's.
    Why not swap out the gq centres until the q is ready, or you buy replacements??
    Or will 4.6 be to high??
    334 Post(s)
    Bump for tappa talk
  12. #1000
    334 Post(s)
    Thank FARK for tappa!!! Been slack on this thread as I have struggled with pics until now.
    Been a busy year, car has been parked up and have been sorting out my 24v for my winch. It's nearlly ready to go but while it's been parked I have also stripped out a heap of junk wiring. I have also made space for a 4" snorkel through the bonnet and big airbox in the future..
    Some wiring mods.
    This is a future plan
    The HiMount is finished and ready to bolt up. 24v ready with +76 Deltatek Freespool and Gigglepin Brake a Shaft. Allbright solenoid. Sexy as Fark!!!
    Gone for a Custom made Big Mouth SS fairlead, you can now buy these on eBay, mine is the one in the pic as it was the first one he made in the bigger size. The big mouth will allow a Brocken plasma to have a knot tied in it and still got through the opening
  13. The Following 4 Users Say Thank You to MudRunnerTD For This Useful Post:
    AB (9th May 2015), Clunk (11th May 2015), Rossco (9th May 2015), Woof (9th May 2015)
