Page 16 of 18 FirstFirst ... 1415161718 LastLast
Results 151 to 160 of 171
Thread: Portable butane stoves recalled in NSW
  1. #151
    Hardcore lucus30's Avatar
    Sep 2013
    16 Post(s)
    Counts me out then
    Thanks Kris
    Im responsible even after I've had 10 cans so I'm good
    Lucus30's 1999 GU ST TB45E
  2. The Following User Says Thank You to lucus30 For This Useful Post:
    NissanGQ4.2 (13th March 2015)
  3. #152
    Feb 2012
    "Hiding Under Your Bed!"
    30 Post(s)
    Digging through my photo's, I found 1 of the connector I made up to use the Coleman disposable bottles with portable BBQ's and 2/3 burner cookers.
    www.swat4x4.com
  4. #153
    Aug 2010
    Lower Blue Mountains
    17 Post(s)
    Quote Originally Posted by oncedisturbed View Post
    I'm guessing that's not legal
  5. #154
    yep did the same as you can buy the adaptors readily at any camping shop and the likes of K-mart
  6. #155
    Sep 2013
    16 Post(s)
    My new stove takes those cylinders natively.
    I still don't know if I'll buy a normal gas cylinder because they are a pain to get filled. Half tempted to buy a swapngo 4kg POL from bunnings so I can just swap it over
  7. #156
    I brought a new 9kg job that the guy up the road fills with forklift gas when required
  8. #157
    Feb 2012
    30 Post(s)
    As TD mentioned, you can buy the conversion kits anywhere. This set of mine is made by Gasmate and I got it from Bunnings and is a legal conversion kit.
    www.swat4x4.com
  9. The Following User Says Thank You to oncedisturbed For This Useful Post:
  10. #158
    So were the Butane Lunch Box Cookers... until...
  11. The Following 2 Users Say Thank You to the evil twin For This Useful Post:
    NissanGQ4.2 (13th March 2015), Winnie (13th March 2015)
  12. #159
    this might be a better option using a 4,5kg gas bottle.
    I've found those green canisters work a treat, even with a thirsty
    cast iron gas ring
    http://www.ebay.com.au/itm/LPG-GAS-W...b1e3f4c&_uhb=1
  13. #160
    Banned in SA now too.
