Page 4 of 6 FirstFirst ... 23456 LastLast
Results 31 to 40 of 51
Thread: ZD30 Blown Piston
  1. #31
    Expert HV2002's Avatar
    Jan 2014
    Camden South NSW
    Need some help guys
    i am trying to remove the timing chain but cant loosen the top cam sprocket its supper tight ... is there a trick to undoing it
  2. #32
    Would you shock it first ,by giving it a "tap" with a hammer
  3. #33
    Unafordable
    4 Post(s)
    Quote Originally Posted by HV2002 View Post
    Need some help guys
    I dunno, I undo things like these with impact air gun. If you can lock the flywheel than large enough breaker bar should help too.
    Regards
  4. #34
    Jan 2014
    Camden South NSW
    Thanks guys....impact gun would be the go if I had one ..might try the hammer TD..other than that it's down to brute strength and a big assed breaker bar
  5. #35
    You need to "crack" it if you only have a brako bar.
    short and fast, buy tapping it with a hammer to shock it'
    you'll break the seal of what ever thread liquid was used
  6. #36
    If your budget doesn't stretch to an air impact set up...
    Years ago I bought one of the Ebay 12 Volt rattle guns primarily for undoing wheel nuts.
    IMHO they are very good value for money at $50 and the gun got so much use around various vehicles on suspension etc I am now on my 2nd one and don't go bush without it
  7. #37
    Are you referring to the Kangaroo creek import 12v style rattle gun that winds up then thump
    http://www.ebay.com.au/itm/DC-12V-Im...item20ee6d3fba
  8. #38
    Jan 2014
    Camden South NSW
    12V gun sounds the go
  9. #39
    Jan 2014
    Camden South NSW
    time and budget leaves me with a breaker bar and hammer ..LOL
  10. #40
    Yes, haven't found a bolt yet they won't move including those "incredible hulk" torque bolts in the diffs
    'K... but I would def would recommend one when you can...
