Results 1 to 8 of 8
Thread: 98 TB45E oil leak solution
    Beginner ISA.13B's Avatar
    Sep 2014
    Sydney
    Hey guys.
    Me again. ;-)
    So, TB45E with an oil leak coming from behind the front belts somewhere. Its making a bloody mess!
    My first assumption is front main seal. I've purchased a genuine Nissan replacement.
    Any suggestions or pointers I should know before I start pulling the thing apart?
    I have a workshop manual, and a decent tool kit.
    Cheers lads.
    98 GU TB45E Patrol - 2" OME + Raw lift, 33" Bighorns, winch, awning etc. etc.
    - Sydney -
    Expert billyj's Avatar
    gordon
    you will need a decent rattle gun and a puller to get the balancer off the crank, then its simple, pop the old seal out and tap the new in gently
  3. The Following User Says Thank You to billyj For This Useful Post:
    ISA.13B (25th February 2015)
    Patrol Freak jff45's Avatar
    Morayfield, QLD
    If it's an auto, you can block the engine through the hole where you unbolt the torque convertor.
    John
    Sep 2014
    Sydney
    Thanks guys.
    Its a manual BTW. Couldn't I just put it in gear to stop the engine turning over and use a long bar to remove the balancer nut or bolt or what ever it is?
    I have a rattle gun, not sure "decent" is a word I'd use to describe it. Its good for threading long bolts in to save my little arms. Not strong enough to undo wheel nuts though. LOL
    Would a bearing puller work to remove the balancer?
    Guessing I shouldn't use a pitman arm tool and lumpy. LOL
    - Sydney -
    Morayfield, QLD
    The FSM shows a simple 2 arm puller being used. I had a quick look for the image but couldn't find it.
    I looked it up some time back because I have to do mine as well..
    John
  7. The Following User Says Thank You to jff45 For This Useful Post:
    ISA.13B (26th February 2015)
    Oct 2011
    Central Victoria
    Quote Originally Posted by ISA.13B View Post
    Hey guys.
    Me again. ;-)
    Cheers lads.
    You sure it's not coming from one of the two sump gaskets? I also have an oil leak down there, and I'm of the opinion that it's the lower sump gasket. (mainly because it's easier to replace than the rear main, or the upper sump gasket!)!
    Sep 2014
    Sydney
    LOL. I'm not sure no Neet Wagon.
    It does look like its coming from higher up the block though. I haven't really had a good look or cleaned the area yet though.
    - Sydney -
  10. #8
    Morayfield, QLD
    The front seal is a common issue for the TB45E. It tends to throw the oil everywhere and will even run to the rear when bad enough.
    Best to thoroughly clean it all first to be sure..
    John
