Page 8 of 11 FirstFirst ... 678910 ... LastLast
Results 71 to 80 of 106
Thread: 2 core versus 3 core radiators
  1. #71
    North brissy
    The oil filter housing has coolant running through and sees this before the returning back down the head so the coolant is already warm.
    An oil cooler is a very good idea. Keeping oil temp in check is also good for your engine. If the oil temp gets to high it starts to lose its ability to lubricate efficiently and as the filter housing is cooled it then transfers this heat to your cooling system.
  2. The Following User Says Thank You to nissannewby For This Useful Post:
    Bloodyaussie (11th February 2015)
  3. #72
    Interesting...
    Would three be potential issues for the oil to be too cold in our vic winters using this?
    Where the hell would you mount it?
    Are you getting one Jonathan?
    Could you mount like a top mount ic with scoop?
  4. #73
    Thomastown, Melbourne
    6 Post(s)
    Mounted here is most common..
  5. The Following User Says Thank You to Bloodyaussie For This Useful Post:
    Bigcol (12th February 2015)
  6. #74
    Interesting...
    Any excuse for a scoop!
  7. The Following User Says Thank You to Winnie For This Useful Post:
    AB (11th February 2015)
  8. #75
    Quote Originally Posted by Bloodyaussie View Post
    No room there....
  9. #76
    6 Post(s)
    No room there....
    Do you want me to purchase the items needed then come around and find a good spot then install it for you? lol !!!!
    Not sure how a top mount oil cooler would go.
  10. #77
    Ill install it myself thanks buttercup but your welcome to buy me one
  11. The Following User Says Thank You to AB For This Useful Post:
  12. #78
    North brissy
    Interesting...
    No issues.
    Anything top mount will heat soak.
    Sandwich plate seems to be the most common.
  13. #79
    Banned
    Feb 2015
    hi i am new in this forum
  14. The Following User Says Thank You to rekha For This Useful Post:
    threedogs (12th February 2015)
  15. #80
    Patrol Freak Bigcol's Avatar
    Sep 2010
    Swan Valley Perth
    11 Post(s)
    Quote Originally Posted by Alitis007 View Post
    How does oil temperature affect water temp??
    well, your water's ability to keep the engine cooler is impaired by the fact the engine & oil is already hot........
    as has been said - very hot oil tends to loose its viscosity (ability to lubricate & ability to transfer heat around)
    if you can keep the engine oil cooler, it will help the coolant in cooling down your engine temps...............
    my understanding of it anyway...........
