Page 1 of 3 123 LastLast
Results 1 to 10 of 21
Thread: LRA auxiliary tank fitting instructions for a GU
    Jan 2013
    Adelaide
    HI all,
    Would anyone have the instillation instructions for the sub tank 75ltr Long Range Automotive tanks? I got one second hand and am unsure if I am missing a bracket.
    Brad
    2005 GU IV 3L ST-S Mods: 3in Zorst, chipped, Autron egt, boost and dual voltage gauges, pillar pod, dual battery, IPF round spoties, Nissan alloy Bullbar.
    Is the tank out of a GQ or a GU? A GQ sub tank will not fit a GU
    Jan 2013
    Adelaide
    It's out of a GU and from what other pics I have seen it is identical. There is just one support bracket I'm not sure about, everything else seems to line up.
    Yes the GQ and GU sub tanks look identical to look at the bracketry is off. If it is a GU then it should basically bolt straight up. Have you checked the LRA site for a PDF Download?
  5. #5
    Have a read of this mate and have a look around there. The basic instructions will be the same for the rear replacement and the sub replacement.
    http://www.longrangeautomotive.com.a...html?showall=1
    Badball (5th February 2015)
    Jan 2013
    Adelaide
    I have measured it up and all seem like it will fit it's just one bracket that I'm not sure of, the rear passenger side bracket. Be good if someone that has one to take a pic, that would be great 😃image.jpg
    Quote Originally Posted by Badball View Post
    I have measured it up and all seem like it will fit it's just one bracket that I'm not sure of, the rear passenger side bracket. Be good if someone that has one to take a pic, that would be great image.jpg
    I have a LRA tank sitting here waiting to go in my Gu. Send me a pm mate to remind me and I'll get a pic for you.
    Heres the pics of mine....
    The allen key bolts on the bottom edges are just on angle iron braces I welded on for protection, as the tank hangs down lower. I will make up a bash plate also I think, hence the allen key bolts there...
    Cheers.
    Mark.
  10. The Following 2 Users Say Thank You to mudski For This Useful Post:
    Badball (19th February 2015), lucus30 (19th February 2015)
  11. #9
    Is that a lra mudski or brown davis
    Dunno mate. I bought it off boots a while back. Just been too busy to install it.
    It wasn't nice a black when I got it too. Gave it a coat of POR15...
    BigRAWesty (19th February 2015)
