Results 1 to 10 of 19
Thread: Spark Plugs
    Jan 2015
    Bray Park, Queensland, Australia
    Spark Plugs
    I have just purchased a 1998, 4.5 liter Patrol and would like to know which Spark Plugs are recommended by the Forum.
    This info should be in the archives have a search and see what you come up with.
    The intro apparently isnt compulsary but its appreciated being polite and all before asking questions
  3. The Following User Says Thank You to threedogs For This Useful Post:
    gene (25th January 2015)
    Expert mjr350's Avatar
    Sep 2014
    Port Macquarie
    NGK BPR5E-11
    In my opinion don't bother with iridium or platnum plugs. They're only out there for engines that are hard to change plugs on or risk breaking expensive leads. My VY LS1 needs 100,000km iridium plugs only because changing standard plugs every 15,000km will most certainly lead to broken leads and the rear drivers side plugs are a nightmare to change. A spark is a spark.
  5. The Following User Says Thank You to mjr350 For This Useful Post:
    Jan 2015
    Thanks threedogs. Gene
    Legendary 4bye4's Avatar
    Aug 2014
    Kingsley WA
    15 Post(s)
    Quote Originally Posted by mjr350 View Post
    NGK BPR5E-11
    What he said times 2 NGK BPR5E-11
  8. The Following User Says Thank You to 4bye4 For This Useful Post:
  9. #6
    Patrol Freak jff45's Avatar
    Morayfield, QLD
    The '11' indicates that they are gapped to 1.1mm
    John
  10. The Following User Says Thank You to jff45 For This Useful Post:
    gene (30th January 2015)
  11. #7
    Sep 2014
    Port Macquarie
    That also doesn't mean you should rely on the factory setting. Always double check with a gauge. Ive pulled a plug out of the box once to find that it was almost closed up.
  12. The Following User Says Thank You to mjr350 For This Useful Post:
  13. #8
    Morayfield, QLD
    And I've seen cases (yes, more than once) where even professional mechanics have hit the side of the plug hole and closed the gap..
    Forgot to mention, I gap mine to 0.8..
    John
  14. The Following 3 Users Say Thank You to jff45 For This Useful Post:
    Chubba (2nd August 2015), gene (30th January 2015), happygu (26th January 2015)
  15. #9
    Sep 2014
    Port Macquarie
    Is your reduced gap due to forced induction?
  16. The Following User Says Thank You to mjr350 For This Useful Post:
  17. #10
    Morayfield, QLD
    Impending forced induction..
    John
