Page 7 of 7 FirstFirst ... 567
Results 61 to 63 of 63
Thread: Got this reply from a tuner about egts from tuning. Opinions needed.
  1. #61
    Patrol God Sir Roofy's Avatar
    TRAFALGAR VIC
    35 Post(s)
    well just drove to the doctors about 15 k using the lower ratio on the auto
    cruising on 60,70 and 80 egts were 200c they went up under throttle and settled back very fast
    Its about 30 degrees ATM in Melb
    yea mine was about the same (manual) went to Warragul about 20ks and back
    at Yarragon there is a slight rise from the lights to near united temp went to 290
    or a tad more then settled back to 220 on the run home
  2. The Following User Says Thank You to Sir Roofy For This Useful Post:
    threedogs (21st January 2015)
  3. #62
    going by your results seems it works on RPM
    and not KPH like most have done. that being the case
    how many RPM at 100KPH for a manual 3 ltr DI,
    please give tyres as either 265s or 285s
  4. #63
    177 Post(s)
    I forgot to get back on this topic. @ 100km/ph flat roat, cruising, my RPM is 2350-2400. 5th gear.
