Page 3 of 3 FirstFirst 123
Results 21 to 23 of 23
Thread: Hydro brakes ?
  1. #21
    334 Post(s)
    I have GU diffs under the GQ and Braided lines with Bendix Extreme pads and it will lock up my 35s without hesitation. Love it! i dont need any more brakes than that.
    The step up from my GQ brake and braided lines to the GU Brakes with the same braided lines is Insane! BIG Step up. I'd do the diff swap for that alone.
  2. #22
    Patrol Freak BillsGU's Avatar
    Jul 2010
    Thurgoona
    7 Post(s)
    I have driven a patrol with a hydro booster setup on it from PID (Heath). It would lock 35's without a drama, pedal was a little heavier but feel was still quite good.
    Funny, I would have expected the pedal to be lighter. The info I got from Mark's says you need less pedal pressure. Mine had ABS so lock up is not a problem.
  3. #23
    Jun 2014
    hydro boost brakes
    Quote Originally Posted by makeitfit View Post
    Any one on here fitted "Hydro Brakes" ? I've been looking into these and in touch with a guy in the States who's going to make mine . However he's told me he's just sent some out before Crimbo to some of you guys in Aus. I figured you must know who it is fitting them down your way
    I'd love to hear some first hand knowledge etc
    Cheers big ears
    Hi I fitted these brakes to my GQ last year best thing ever done. IM running 35inch tyres truck weighs about two tonne will lock all wheels with little effort. Just be aware you may have to change master cylinder the original may leak. They say you can use the original steering pump but I found when brakes where in use the steering became erratic very heavy then ok very unsettling if you are going around a corner. I had a new master cylinder matched to hydroboost form USA much easier and cheaper also had new pump sent from USA. I had to make up mounting brackets but not much effort. Also made up my own hydraulic lines using aero fitting they just screw together all less $100 to expensive to have them sent from USA. Not necessary to use braided lines. do a search on googgle you find they perform no better than normal rubber brake lines. yes they do look better but very expensive. If you want fotos or any help just ask.
    AL
  4. The Following 2 Users Say Thank You to ala For This Useful Post:
    makeitfit (21st January 2015), Ropes (7th December 2016)
