Page 6 of 7 FirstFirst ... 4567 LastLast
Results 51 to 60 of 63
Thread: Got this reply from a tuner about egts from tuning. Opinions needed.
  1. #51
    Quote Originally Posted by Rock Trol View Post
    Thanks ET. The reason I changed the scangauge from MAP to boost was because most people use this when posting on forums so it was easier to follow what was going on. I will change it back to MAP.
    What MAP psi should I be looking at?
    - Cruising at 100kph - 27?
    - Foot to the floor? (35-40?)
    Depends on the vehicle, Dawes or ECU, VNT tweaked or factory, load, etc
    I would SWAG it as 30 ish MAP flat wack and 25 ish at 100
  2. #52
    476 Post(s)
    Quote Originally Posted by paulyg View Post
    Hey mudski how many psi do you have at 100kmh?
    About 18 mate.
    When you guys are talking about running 20-25psi boost, is that just a peak before it drops down or is it steady at that boost?
    Mine is peak. When I'm giving it the berries....
  3. #53
    Legendary big_fletch's Avatar
    Oct 2010
    Tatura VIC
    I have 2.5" lift (closer too 3"), 33's, roofrack, drawes, winch ect..
    I Have a Voltage Modifier on my MAF in my troll so I run 9 psi roughly at 100km/h, EGT'S around 320 degrees.
    Max boost at 20psi and I can hit that going up a hill or headwind putting my foot down and sit on 20psi all day long till I reach the top.
    EGT'S even towing nearly 2ton with a/c on I'm struggling too go over 500 degrees.
    I'm averaging 11.8ltrs per 100 atm on Highway without towing, around 15.5-16 towing just under 2ton.
    I'm still using factory MAF housing as well and VNT turned down 1/4 of a turn
    I may get a boost spike too 22 psi but drops straight down too 20psi and sits there till I back off
    Fletcha
    Qualified Auto-Electrician
    Apprentice Sparky
    Dont own a Patrol or any 4WD at the moment, hopefully will change into the future
  4. The Following 2 Users Say Thank You to big_fletch For This Useful Post:
    Badball (23rd January 2015), the evil twin (19th January 2015)
  5. #54
    Patrol Guru Rock Trol's Avatar
    Mar 2013
    NE Melbourne
    I have Dawes and needle valve on mine (EGR block). Driving to work today if I gave it a bit it would go to 29 psi MAP but stayed around 20 most of the time so sounds about right until I get onto the highway.
  6. #55
    Too low... give it a bit of a tweak I reckon.
    I recall someone saying crank it till it limps and back it off a tad... or was that wheel nut torque (do one up till it snaps and back the wrench off 5 ft/lbs).
    Mind you I've never set up a Dawes and Needle so what would I know
  7. #56
    476 Post(s)
    Just remember. The max boost is relative to the cruise boost. I.e 100kph boost. The best results I have found is around 8psi difference between max boost and 100kph boost. So the higher mac boost you go the higher cruise boost too. If not you will find the spool up rate of the turbo too slow and the engine sluggish. I will vary a little between cars but thats an average.
  8. #57
    Mar 2013
    NE Melbourne
    I'll try that on the weekend Mudski. Car feels pretty good though. When I had it set on boost it would sit around 12psi at 100 and max at around 18. Its a CRD so running a bit more boost is probably good for it. I read on here that 10psi at 100 is good but I could not adjust it down that low as the spool rate was too slow and car felt sluggish. When I adjusted mine I found a sweet spot and if I tried to go over (more boost) or under it the car did not run as well. Might tinker with it a bit more when I get the chance.
    With the scangauge set to MAP what is a good max boost? 35psi? I think that equates to about 20psi boost. When I turned the car off today I kept an eye on the scangauge and it came down to 14.3 psi which I think is the atmospheric pressure. That would make the 29psi MAP about 15psi boost which is pretty good.
  9. #58
    Advanced Remdogg's Avatar
    Jul 2013
    Meadows SA
    That's pretty well what my crd is set on and feels good. More boost did have my egts lower when I was flogging it but went to limp mode after about a week so I took 2 psi out of it. Spikes to 20 then settles to 18 and cruise is about 12 ish but very hard to measure. Haven't hit limp again.
  10. #59
    Been driving my auto in the lower ratio the last two days EGTs are around 200C
    so revs has a lot to do with it as well
  11. #60
    well just drove to the doctors about 15 k using the lower ratio on the auto
    cruising on 60,70 and 80 egts were 200c they went up under throttle and settled back very fast
    Its about 30 degrees ATM in Melb
