Page 6 of 43 FirstFirst ... 45678 ... LastLast
Results 51 to 60 of 430
Thread: Bloodyaussies TD42 a new beginning
  1. #51
    Quote Originally Posted by roofy View Post
    winnie your turn
    Hahahaha! Thanks roofy! I could think of a million things but I'll save it all for the weekend =)
    Sir Roofy (18th January 2015)
  3. #52
    Thomastown, Melbourne
    6 Post(s)
    Well the Australia day meet has come and gone and was a very good test to see how Bruce's heart transplant has gone...... I must say very well indeed.
    The drive up was perfect with Growler and I both having accurate digital temp gauges and comparing notes and also comparing with AB's intercooler and Daz was overheating so not much to compare there.
    My water temps were very good towing a trailer going up those long hills in NSW on a pretty hot day with temps peaking once at 99 degrees once and the rest of the time averaging 94 on the big hills.
    Intercooler temps were never a problem but AB's one the day in that department with about 60 degrees on average cooler than Growler and myself.
    The car was a smooth as a babies bum and I could not fault it.
    On the drive home both water and intercooler temps were affected.. the water temps were about 2 degrees higher but still managed to not go over 99 degrees and the intercooler was the same but took longer to come down.. upon inspection the intercooler was blocked up a bit and the radiator will have to come out again to be cleaned properly as there is a fair bit of crap jammed around the bottom and the compressed air cannot get to it.
    At the Meet up I did have some problems only to do with being a child and playing in the mud ... I snapped an alternator belt just as I got back to camp and wondered why I lost brake pedal and clutch and my first assumption was a vacuum leak.
    When I replaced the belt (thanks to Winnie and offers from 500 others.) I must have pulled the small vacuum hose off and with higher revs brakes and clutch were not a problem but as I got home I had no brakes at all.
    My rear brakes also got stuck on a number of time and after a couple of hits with a hammer they freed up but I am thinking the problem lies with the brake bias as it seems the rears are working way too hard and the fronts are not even warm when I check them?
    I have just spent nearly 2 hours unpacking and cleaning the inside only and will head off to get filthy cleaning the outside...yuck!!
    After this trip I am convinced of the TD42 with a turbo and would swear buy it.
  4. The Following 6 Users Say Thank You to Bloodyaussie For This Useful Post:
    93patrol (28th January 2015), Clunk (27th January 2015), Family4x4 (28th January 2015), mudnut (27th January 2015), Rossco (30th January 2015), Stropp (28th January 2015)
  5. #53
    477 Post(s)
    Quote Originally Posted by Bloodyaussie View Post
    As you have lifted Bruce a fair bit. Have you got an extension bracket for the bias valve in to compensate for the lift?
    Also after my trip up, around and back from the Sapphire coast dragging a 1.4T camper I am also convinced of a TD42 and turbo, plus intercooler. Not that I needed convincing of that... Lol.
    Good to see you came out with minimal issues.
    Bloodyaussie (27th January 2015)
  7. #54
    yeah agree not 100% convinced the mighty ZD30 is right for towing anything over one tonne
  8. #55
    Patrol Guru matfew's Avatar
    Nov 2012
    When you lift it makes the bias valve higher and hence it doesn't work after all. Eg it thinks the back of the car is lifting under heavy braking so gives it less rear brakes so not too get a brake lock up.
    If anything it would not be working at all with lift so sounds as if it's been over compensated or something weird going on with front callipers
  9. The Following User Says Thank You to matfew For This Useful Post:
  10. #56
    6 Post(s)
    I have that bracket fitted and after I put that hose back on the alternator (the little one) my clutch and brakes feel very good..
    It may have been they were just so mud encrusted.
    3 hours so far cleaning my car... I am glad I spent more time at Kris's cleaning under the car than worrying about the body as it made cleaning so much easier today.
  11. #57
    @ BA figured out your fuel figures yet??
  12. #58
    Pretty impressed by your engine mate, happy ending finally!!!
  13. The Following User Says Thank You to AB For This Useful Post:
  14. #59
    6 Post(s)
    I'd like a happy ending with you sweet cheeks.....lol
  15. The Following User Says Thank You to Bloodyaussie For This Useful Post:
  16. #60
    Ill need beer and lots of it
  17. The Following 2 Users Say Thank You to AB For This Useful Post:
    Bloodyaussie (27th January 2015), Stropp (28th January 2015)
