Page 35 of 52 FirstFirst ... 3334353637 ... LastLast
Results 341 to 350 of 517
Thread: Blocking the EGR Valve
  1. #341
    Beginner snakessou's Avatar
    still a thread that I link to friends who have got themselves a patrol. great option but sadly have not done it myself.
    on a similar subject, what function do the egrc-valves a and b and the throttle control have and how do we as home mechanics use those to our advantage?
  2. #342
    Just block the egr on the engine mate and don't worry about the other two thingo's.
  3. #343
    sounds like a flawless plan but still interested in what they do.
  4. #344
    Quote Originally Posted by snakessou View Post
    Wouldn't have clue bud. Not real familiar with the crd's.
  5. #345
    They are part of the Di's , you won't find them on the CRD's.
    The CRD's have a completely different EGR system to the Di
    Di's use 3 electrically operated vacuum ported solenoids (as shown in his piccy) to control the EGR and Throttle valve for 1 of 4 settings
    As well as having water cooled EGR the CRD's use an electrically driven motor wired to the ECM to position the EGR valve which is fully variable.
    The EGR on the CRD's is much more responsive and significantly less likely to produce boost spikes.
    Bottom line tho, is you are still 'breathing your own farts' as was so aptly put the other day so, yeah, just block the sucker
  6. The Following User Says Thank You to the evil twin For This Useful Post:
    snakessou (24th January 2015)
  7. #346
    Feb 2011
    Shed
    45 Post(s)
    They are part of the Di's , you won't find them on the CRD's. The CRD's have a completely different EGR system to the Di Di's use 3 electrically operated vacuum ported solenoids (as shown in his piccy) to control the EGR and Throttle valve for 1 of 4 settings As well as having water cooled EGR the CRD's use an electrically driven motor wired to the ECM to position the EGR valve which is fully variable. The EGR on the CRD's is much more responsive and significantly less likely to produce boost spikes. Bottom line tho, is you are still 'breathing your own farts' as was so aptly put the other day so, yeah, just block the sucker
    Does the CRD EGR blanking plate need a hole in it? I thought I'd read somewhere it did
  8. The Following User Says Thank You to growler2058 For This Useful Post:
  9. #347
    A small hole will stop the ECU throwing occasional P0401 fault codes (EGR Volume error).
    I didn't drill mine tho.
    Every CRD owner should have a scanner, crazy if you don't IMHO, so all you do is reset the fault on the rare occasions you happen to get them.
  10. The Following 2 Users Say Thank You to the evil twin For This Useful Post:
    growler2058 (12th January 2015), snakessou (24th January 2015)
  11. #348
    The pic posted is from a crd though....
  12. #349
    Well, thats damn odd, disregard my prev... Confused am I (in my best Yoda voice)
  13. #350
    Haha, with the hMm! In the Yoda voice too.
