Page 20 of 23 FirstFirst ... 1819202122 ... LastLast
Results 191 to 200 of 230
Thread: What Oil Do You Use for Diesel Engines?
  1. #191
    476 Post(s)
    Quote Originally Posted by SG1 View Post
    Switched to Delo 400, Can get at the Traralgon Caltex Truck stop on princess highway (20L drums), have noticed a bit more blow by in the catch can since using it, seems quiter than when I had the penrite 10-40w semi synthetic but want to change to penrite 5-40w as then it would be all penrite oils in the vehicle or really considering the Castrol RX Super, still not sure which way to go..
    I used to sell Castrol a few moons ago now. I still keep in contact with the rep who's been there for donky's. RX Super is not recommended for the ZD30's but the rep was confident that I could use it. But I wasn't. So I have kept on with Magnatec Diesel 15w40. Been using that since day dot and start ups are really quiet and I catch around 150ml of oil in the catch can every 5k service. I did switch to Delo 400 a while back after reading all the hype. After using it for 3 services the motor, used a little oil, had more in the catch can and was noisy on start up. So I switched back and haven't looked back. SCA have the Magnatec on special at nearly half price every now and then on the 10L so I stock up when I can.
    One thing you need to remember though is, if you do switch oils, stick at it for atleast two changes, minimum. As different oils use different additives and your motor will react differently maybe to not what you like. But it may settle down, give it a go...
    But I wouldn't be using RX super in a ZD30. TD42? Hell yes!
    SG1 (6th January 2015)
  3. #192
    anyone use RX Rimula R4x? is it good for zd30?
  4. #193
    Expert SG1's Avatar
    Sep 2014
    Gippsland, Vic
    Ok, so for the ZD30 its Delo 400, Penrite 5-40, or Magnatec 15-40, or Nissan oil..
    Was confused as read some were running RX Super or thinking of switching to it soon/next service but have now realised they must be talking about the TD42.
    Like the Delo and runs good but same found more in catch can than was expecting and used a small amount, might go the Penrite or Magnatec then, still got 500k's to decide.
    02 GU ZD30 Auto, NADS, Setting up for touring and camping, Best thing is the missus loves driving it to..
  5. #194
    I'm using Castrol Magnatec 5-30W in my GU9 CRD. I used to use Magnatec 5-40W in my YD25 Navara and it ran beautifully.
  6. The Following User Says Thank You to docp1980 For This Useful Post:
    growler2058 (9th January 2015)
  7. #195
    Feb 2011
    Shed
    45 Post(s)
    I gotta do an oil n filter change before the Aussie day meetup dunno what im gunna get now
  8. #196
    Oct 2010
    Old Bar, NSW
    Been using Penrite 15W-50. At $72 for 10 litres it's pricey. I had a credit balance of $32 on my Supercheap car so grabbed some yesterday at near half price, schweet.
    Macca
  9. The Following User Says Thank You to macca For This Useful Post:
    growler2058 (11th January 2015)
  10. #197
    476 Post(s)
    How good are those Club Plus Card Hey? One would be mad not to have one.
    macca (11th January 2015)
  12. #198
    Oct 2010
    Old Bar, NSW
    Yeah, Ive probably scored 200 - 300 dollars easy from them.
    Macca
  13. #199
    Patrol God Sir Roofy's Avatar
    TRAFALGAR VIC
    35 Post(s)
    Quote Originally Posted by trol3.0 View Post
    was a good read lot of oil testing though
