Page 25 of 28 FirstFirst ... 2324252627 ... LastLast
Results 241 to 250 of 277
Thread: Growlers' GU DX
  1. #241
    Feb 2011
    Shed
    45 Post(s)
    Quote Originally Posted by megatexture View Post
    May as well rip off the rear mud flaps and the little wheel arch bits under the rear doors as they will all come off eventually with even mild 4wheeling
    Yeah those little bits are what I put back on!
  2. #242
    brisbane
    It looks fine without them and they will continue to fall off, mine lasted a 3 weeks before I binned them
  3. The Following User Says Thank You to megatexture For This Useful Post:
    growler2058 (3rd January 2015)
  4. #243
    Mar 2013
    How many K's did your GU have on the clock?
    Will you be doing the Dawes and needle valve installation and blocking the EGR? and a Catch can?
    Is it recommened to clean the inlet manifold?
  5. #244
    Feb 2011
    Shed
    45 Post(s)
    Quote Originally Posted by SKID View Post
    How many K's did your GU have on the clock? Will you be doing the Dawes and needle valve installation and blocking the EGR? and a Catch can? Is it recommened to clean the inlet manifold?
    It had 145k and at the moment no plan on dawes or any of the NADS. I've cleaned the MAF and have monitored boost with a scan gauge. If I'm ever allowed to spend more $'s on it ie exhaust I'll get an EGT gauge. Maybe just maybe a catch can.
  6. #245
    22 Post(s)
    You can buy cheap endoscope extensions for your camera, why not get one of them and have a look in the intake manifold and around the valves etc and see if there is any bad buildup of egr gunk in there
    http://m.ebay.com.au/itm/221259363836?nav=SEARCH
    96 GQ coil/Cab
    08 G6eT
  7. The Following User Says Thank You to Ben-e-boy For This Useful Post:
    growler2058 (12th January 2015)
  8. #246
    Feb 2011
    Shed
    45 Post(s)
    First superior stuff I've ever had. And it was FREE!
  9. The Following 2 Users Say Thank You to growler2058 For This Useful Post:
    Stropp (15th February 2015), threedogs (15th February 2015)
  10. #247
    I'd probably do a catch can , if nothing else ATM and
    do the EGT as you said when you do the exhaust.
    I removed a perfectly good exhaust , sort of regret doing it.
    Hot as over there still ?
    Can't beat free stuff IMO lol
  11. #248
    Nice. Simple but clever
    Feb 2011
    Shed
    45 Post(s)
    Yup still HOT 37.7
  13. The Following User Says Thank You to growler2058 For This Useful Post:
  14. #250
    Mar 2013
    Good idea I got an endoscope here I use for data cabling...
