Just a bit more on what evil said you can rule out the ecu by using a needle and Dawes valve set up
Try spinning the turbo impeller with your fingers. See if it spins good and there is no play in the shaft.
And if it does spin ok ? I have also read about a vacuum boost pump (?). What ever site I was on says its mounted under the intercooler, but I don't appear to have one on my vehicle ?
It is also taking a little bit to fire when starting, is this a vacuum or fuel issue, I think it is related to my initial problem
Ok boys and girls, some of you may remember my lack of boost issues. Now I'm back at work I have borrowed the scan tool and found that the MAF sensor is registering as the fault code....
Thank you all for your input and advise, it has been very much appreciated.
I also have a few pics with numbers and percentages that I don't understand... Any help would be great.
Hmmm, now I need to upload pics..... Back in 5
