No idea what you are referring to.
ahhhh... setting new lowest standards for a post to get the manuals.
BigRAWesty (28th December 2014), growler2058 (28th December 2014)
Has anyone had one of these engines on a dyno?
Ok, so I have finally gotten around to getting my tranny coolers re-positioned and a big ass thermo fan installed, and yes it seems to make a huge difference. The coolers are the ones supplied by Wholesale Automatics and are made by PWR. Nothing special really, they are thin but fairly large. Due to a lack of space in front of the radiator, I had previously mounted one in front and one slightly lower, more directly behind the winch, and temps were still a bit high.
I now have the two coolers mounted back to back with a fan pushing air through them. Looks like this:
First install of the thermo fan was behind the coolers, and pulling air through, however I think because they are mounted together this wasn't working very well. Mounting the fan in front saw an 8 degree drop in temps comparatively.
At the moment, the thermo fan runs constantly from startup and is fitted with a shut off switch on the dash in case of a deep water crossing. The shut off switch has a nice bright blue LED in it which illuminates when off, just in case I forget to turn it back on. I may yet change this around and run the thermo off a temp sensor but this is it for the time being.
I also fitted up one of the Aussie made Engine Watchdog's, the TM4 version with the twin sensors and oil pressure alarm. This little unit is just sitting on the dash at the moment until I decide where I finally want it.
The transmission sensor is positioned on the back of the pan.
My first test run saw the tranny temps between the Engine Watchdog readings and the Compushift II showing some big differences and I am trying to work out why. The watchdog sensor would have a reading of say 60 degrees, and the Compushift would be reading 76 degrees. A whopping big difference. I can understand that the internals of the box, or the fluid itself would be hotter perhaps than the base of the transmission, but 16 degrees difference seems like a lot to me. If anyone can shed any light on this I would be keen to listen. I am hoping that the sensor location is ok.
Previous runs at this same location used to see transmission temp readings on the Compushift get to around 93 degrees. This time, it got to 80 degrees with the watchdog only reading 63 degrees. A huge drop in temps. Now I am wondering what the optimal temperatures are for the transmission, and whether this is even a fraction too low?
80 degrees fluid temp is OK.
The watchdog thermocouple won't read anything like the same as the Compushift temps.
One is fluid temp, the other is whatever heatsoak has gotten to the edge of the pan flange.
FNQGU (23rd January 2015)
Thanks. Tranny temps now seem really good.
Engine temps around town are sitting between 91 and 97 degrees, and climbing to 103 degrees when worked a bit going up the range. I wouldn't mind getting these down a bit too. I think that the location of the tranny coolers might be restricting air flow through the radiator a little too much. Another headache...
Just seen an F350 with a 6.7l turbo'd engine and running a 4in exhaust. I got told ages ago to fit one and promptly forgot about it. Mine's got a 3in exhaust.... Is there much, if any, benefit in changing up to a 4in exhaust?
2006 Ser IV GU, 6.5l TD V8 Chev with 4spd Auto, 3in Lift, 35in Kumho's, 12000lb winch, Nissan snorkel, Diff breathers, lightbar + Lightforce HD spots on roofrack. Built to go bush.
Gecko17 (2nd March 2015)
I have seen it done with the 6.5s the 6.2s but not on a GU
